[Wanted] W211 Bluetooth module
Discussion in 'Spares for Sale and Wanted' started by tighthead, Jan 6, 2013.
  1. tighthead
    tighthead New Member
    Jan 6, 2013
    W.GLAM
    Your Mercedes:
    E280 2005 CDI
    Wanted. A bluetooth module for an E class 280 2005.
  2. The Pan Man
    The Pan Man Senior Member
    1,254
    Sep 27, 2004
    Warwickshire
    Your Mercedes:
    2008 E 500 A/G Classic colour combination.
    Not a ball breaker from a dealer, Cheaper options available a comand online, Worth a call these guys are sponsers on here and do know their stuff.
    Worthy of note, Your contacts list will be in a format that you can't change(?) and take a little while to get used to. Quick e.g. If like me you have several names e.g. Bill Home, Pat Home. These will display alphabeticly as Home Bill Home Pat so are stoted under H rather than the other way round, If there is a way to change the dispaly I have yet to find it.
  3. V6Matty
    V6Matty Senior Member
    6,770
    1,527
    Aug 1, 2012
    Newark, Notts
    Your Mercedes:
    S212/10/E350(His) W169/2005/A180 (Hers)
    Sorry for hijacking the thread.
    from memory this is how its collected from your phone, so how you have saved it in there, it associates as surname then first name. try saving (for example) Pat Home in the surname on your phone and it should then display like that in the display in the car?
    Not tried it myself as i don't have BT but it may be worth a go ;)
  4. V6Matty
    6,770
    1,527
    Aug 1, 2012
    Newark, Notts
    Your Mercedes:
    ok back on subject, what audio unit do you have in your car and also does it have phone prep? you should be able to see if it had phone prep by posting your cars VIN number in the VIN Decoder thread and some very helpful person should be able to supply you with your Data Card. another quick way would be to see if there is a phone cradle in the centre armrest?
    hope that gives you a couple of things to go at to start with.
Share This Page
