W211 Door Lock
Steve Taxi
Malvern, Worcs.
W222
I have a drivers door lock gone bad, the usual bouncing lock problem, took the lock out today and found a broken spring inside it, so I ordered a new one coming in 2 days, the dealer tells me it will need programing before it will work, now I fell for this the last time one failed and let them fit it but will it really not work until they have worked their magic?
It plug and play as far as I know,,I have sent out the info loads of times,,,they were probably getting confused with getting a puncture where the wheel has to be re set on STAR
:rolleyes::rolleyes:
Steve Taxi
Malvern, Worcs.
W222
Thanks guys, as I thought, I have just replaced a front interior light unit with a second hand one, the dealer wanted £200 inc "reprograming"
How can we re program the dealers :confused:
Steve Taxi
Malvern, Worcs.
W222
Sorted, it only unlocked at first but then started to lock as well after it had had a think about it, one other thing worth noting the key lock and sensor have to be removed before you can get the unit out, to do this there is a hidden screw behind the door seal through a hole.
Alex Crow
Super Suffolk
hi steve, when you put them in and try them straight away and they only lock you scratch your head. but then you refit the latch trim on the door, which contacts the door pin switch, and hey presto. :lol: had me scratching my head first time.
flaxon3
Dublin
W320cdi W211
Hi Guys,
Is it possible to get a copy of the document showing how this is done - I am about to replace my old door lock with a replacement and could with some guidance.!!!
Mark
Just pop up your Email adress and I will sent the info,,is this for a front door
flaxon3
Dublin
W320cdi W211
yes, its for the drivers door.
many thanks.
mark.
ma§§§§§§§§§§§§§§§om - yes, its for the drivers door.
many thanks.
mark.
Both sent,,you can edit out the address now
drdre78
london
mercedes c200 200
hi they told me all mercedes cars tyres you need to use mercedes air to pump them up.lol
Yes it would be a bad thing to do with anything else
Alex Crow
Super Suffolk
the air is chassis coded, and comes direct from stuttgart.
flaxon3
Dublin
W320cdi W211
Hi Malcolm,
Many thanks for the docs, all went weel except, the new lock doesn't move when I lock the car, almost as if the the sdystem doesn't recognise the new lock, I tried plugging the old one back in and got the same result,
Any suggestiomns??
Mark.
I do not know the answer to this one unless a fuse has blown,,There maybe something in WIS and I can look this evening
flaxon3
Dublin
W320cdi W211
Just discovered that it will unlock (both new and old) but not lock, so if I lock the car, all other doors will lock, but not the drivers door, but if I press the button down, then the door is locked and will unlock along with the others when I press the unlock button - wierd eh??
flaxon3
Dublin
W320cdi W211
Ok, so I reassembled everything, mounted the door card, cleaned all surfaces, and now it works, everytime.....
www.ckinsurance.co.uk
