W211 E220 CDi - Running Temperature
MLAM
Hampshire
W211 220 CDi (Facelift)
Hi all,
I was out in the old mans E220 CDi (170 BHP) today and I was looking at the temperature gauge, despite a good 30 min drive it didn't go above 80 degree's, it sat about 1 or 2 bars below.
Is this too cool for this engine or given the cold temps we have had lately it's about right?
I then drove the car on the way back an gave it some beans and it rested on 80 degree's a bit but settled back down to about 2 bars below.
Also another note, how should these things shift when giving it some beans? the gearbox and engine do seem quite responsive and you feel it drop a gear or 2, is this the norm?
Any advice appreciated, thanks
rpe2
Silchester
A couple of bars means about 60c
Probably needs a new thermostat - quite common.
It is failing as above,, it does need to be in the mid 80's or more
M
MLAM
Hampshire
Thanks for the advice guys.
Do you guys tend to go for Genuine parts or get pattern part from ECP or GSF?
turbopete
Spennymoor
i replaced mine about a year ago with a genuine one and, from memory it cost about £44 for my C220 CDi
If you would like the worksheet, just ask
M
MLAM
Hampshire
Thank you all,
Does anyone have the part number for the Thermostat?
Troon
Staffordshire
A big one
For my car, it's A6462000015, which includes the gasket. If you post your VIN we can check EPC for you.
Troon
Staffordshire
A big one
I replaced mine yesterday -- car was hovering between 70 and 80 deg C on long runs. With the new 'stat, it runs at a steady 90, and first indications are that economy is improved.
Replacement is fairly easy on the OM646 -- you need an E10 Torx socket and a 6" extension bar, both available from Halfords.
M
MLAM
Hampshire
Hi Troon,
The VIN is WDB2110082B059999
I spoke to a specialist today and I was advised they should not run hotter than 90? :S
I'll keep an eye on it, I take it you bought yours from a Dealer?
Troon
Staffordshire
A big one
Hi Troon,
That's the correct part number then. The thermostat should keep the temperature at 90-ish. Mine, like yours, was running a couple of bars below 80.
I bought it from Inchcape's online store.
M
MLAM
Hampshire
Thanks for your reply Troon.
Given the cold temps in the winter should the engine reach 90 Degree's regardless albeit a bit longer time wise?
How many bars above 80 does it sit now?
Troon
Staffordshire
A big one
Two bars above 80 and two below 100, which I assume to be 90°C. It got there in nine minutes from start this morning, driving gently in 1.5°C ambient; and did not move off that position throughout my 50-mile commute.
I have half my radiator blanked off, but I'd still expect it to reach 90°C.
Jorge Olili
E220 CDI 2006
Mine has been Operating at 95°c. So I need another Thermostat? Some people have been saying its Normal but the again I'm in Kenya some Regions Push as Much as 29°c to Highs of 32°c. Tropical operating Temperature for W211 E220 CDI 06'?
Kev555
N.I
95 degrees is a bit too close to boiling point for me or is this the highest point it gets to on hills etc? at your regions temperatures Jorge. I take it in your dry climate dust is possibly a problem in your region? if so make sure radiator fins aren't clogged with dust and maybe a cooling system flush would do no harm either. You could try a lower opening temperature thermostat if one is available.
95 degrees is a bit too close to boiling point for me or is this the highest point it gets to on hills etc? at your regions temperatures Jorge. I take it in your dry climate dust is possibly a problem in your region? if so make sure radiator fins aren't clogged with dust and maybe a system cooling flush would do no harm either. You could try a lower opening temperature thermostat if one is available.
Boiling point is increased with antifreeze so 95’ shouldn’t be an issue
Jorge Olili
E220 CDI 2006
Like for Instance I have Been stuck in traffic for the last 3hours an this is how it is. I will try and enquire about a Possible Supply of a Lower Temperature Thermostat Tomorrow. And Yes, We have a lot of Dust all over with all the Road Constructions Sites around the City.
Jorge Olili
E220 CDI 2006
Cluster Image.
