W211 E280 CDI Turbo failure
E280 CDI 2009
Ive had a turbo (reconditioned) end of Jan 19 installed - on driving away the car now goes into limp mode if I drive continually over 150 miles. Stop car it resets and like nothing happened.
Ive had it plugged in to star with an independant MB garage and it comes up with
2510-001 check component Y77/1 (boost pressure regulator). Positioner
Been told turbo actuator is duff and needs another turbo - person I got the refurbished one from wont answer my calls even though it has a 2 year warranty.
Will I ned a new turbo and who best to get one from or just let the indy do it?
  • Autoclass MK star.pdf
D
E280 CDI 2009
  • #2
Ive put this in wrong forum!
Hi buddy , there is a common actuator fault where one of the soldered links on the outside of the electronic board inside the actuator break . There is stuff on YouTube , try searching "Mercedes om642 turbo actuator ?" I'll try and post more later , Mrs Wighty is dishing dinner up
D
E280 CDI 2009
Cheers lofty
I’ve been told you can’t teplace the actuator but need a complete new turbo
Is that correct
I did have loads of other faults O2 sensor but all cleared when recon turbo fitted but when I drove up to that there London Village ir went into limp mode after 150 miles - hasn’t done it again for 2 weeks probably because I haven’t driven more than 60 miles with stopping.
There is also quite a bit of black soot around the exhaust
bembo449
gainsborough , lincolnshire
you can get refurbed ones off fleebay pal , im running one now as it happens , defo go legal on the supplier of the turbo !
D
E280 CDI 2009
Had another recon turbo fitted by auto-class in Milton Keynes - awesome customer service and hoofing job! My Merc seems to have a lot more torque than before!!!
turbochargers4u- who I got the 1st recon turbo from won’t return my call won’t answer the phone or reply to my emails!!! Don’t touch this twat with a barge pole!!!
Glad it's fixed , has that sorted out all your fault codes ? What did auto class reckon was the problem ?
D
E280 CDI 2009
Pressure regulator sensor thingy
See Star report above mate
Only had the car 5 months and it just seems to be a lot more torque and quicker off the mark - car rev counter is good and changes gear awesome
Uncle Benz
West Sussex
Mainly Mercedes
I'm sorry to say, but a company with a name like turbochargers4u would immediately raise my suspicions.
D
E280 CDI 2009
Not being a petrol head or mechanically minded in any way shape or form - I was recommended to this and was even given the part number on their www to buy.
In any case CC Company are on it!
