W211 E280 washer bottle access
Discussion in 'Bodywork, Tyres, Wheels & Trim' started by veverett, Nov 10, 2012.
  1. veverett
    veverett New Member
    9
    Sep 11, 2005
    Can anyone point me to a link on how to get access to the washer bottle on my 2006 W211 ? Just had to fill up twice in a week I suspect a rotted grommet, but no idea how to get access to the tank ? sorry if this is a FAQ :-(
    Cheers Vin
  2. television
    television Always remembered RIP
    164,074
    310
    Your Mercedes:
    It is in the offside rear section of the front wheel arch, and the line has to be removed
  3. OP
    veverett
    veverett New Member
    9
    Sep 11, 2005
    Ah thanks at least I don't have to take it all out, I had a grommet go on my old W202 just bought the grommet and popped it in. Modern hocum with hiding everything, still I expect the liners cut down on the rust.
    Thanks again.
    Cheers Vin
  4. television
    164,074
    310
    Your Mercedes:
    I do have a paper on this if you need it
  5. OP
    veverett
    veverett New Member
    9
    Sep 11, 2005
    Thanks I should be Ok.
    Cheers Vin
  6. MotardMan
    MotardMan Senior Member
    888
    10
    Apr 3, 2003
    Stroud, Glos, UK
    Mine leaks too, is it too late to post a pic how to on this? Happy to do it so other Googlers find out how.
  7. television
    164,074
    310
    Your Mercedes:
    The pipes that go to the lamp washers can leak
  8. OP
    veverett
    veverett New Member
    9
    Sep 11, 2005
    Thanks I had used the light washer the day before, took the inner wheel cover off I had one pipe a bit loose so put a clip on it and its seems fine.
    Releatively easy to get to, but a lot easier on my old C240 :-(
    Thanks for replying
    Cheers Vin
Share This Page
