[Wanted] W211 Estate Power Close Latch
Discussion in 'Spares for Sale and Wanted' started by confounded, Dec 2, 2012.
  1. confounded
    confounded Guest
    I am looking for a replacement for my recently failed tailgate latch. It has a part number of A2117400135, although I believe this has been superseded by A2117400535
    markpickard at metronet co.uk
  2. Troon
    Troon Active Senior Members
    917
    3
    Sep 16, 2011
    Staffordshire
    Your Mercedes:
    A big one
    If it's the same as the one on my facelift without power tailgate, the latest part is A1647400635. My tailgate soft close motor was intermittent and wouldn't even latch with a slam. I bit the bullet and bought the new part from Inchcape at a touch under £250 delivered, and fitted it a couple of days ago. Right as rain now.
    If you PM me your VIN, I can check if that part also applies to your car via EPC. EDIT: just had a play on EPC, and I see your number (...535) is the latest for seven-seaters.
    I had to use the car between removing the old latch and the new one turning up in the post:
  3. OP
    confounded
    confounded Guest
    Hmmm, trying to avoid paying that much, my main dealer quoted £235 and was a bit shocked.
    My car is a 53 7 seater and I have been trying to sell it for the last month, gutted this has gone wrong now.....
    Thanks for your post.
  4. SteveCmerc
    SteveCmerc Member
    Oct 2, 2012
    Devon
    Your Mercedes:
    E270/2004/diesel
    My motor gone awol also. Did anyone find a way of making it manual closure only ?
    What is the power input feeds on the multipin connector so I can try this before ripping apart ?
    Steve
  5. television
    television Always remembered RIP
    164,074
    310
    Your Mercedes:
    It is often just dirty micro switches within the locks
  6. SteveCmerc
    SteveCmerc Member
    Oct 2, 2012
    Devon
    Your Mercedes:
    E270/2004/diesel
    At least you are optimistic ! (tailgate light problem eventually was mucho cash for new rear light cluster + sensor unit flooded by rear wash fluid, but thanks for info on how to get in the tailgate) I'll open up the plastic housing carefully till the welded tags snap off and see what I can do cleaning up the microswitches etc. At present there's no motor noise even when you manually close the latch. It was getting lazy recently until stopped altogether. Is there any virtue in bending the lugs on the metal housing bit and trying to get in that way, or will the spring fly off ?
    Steve
  7. television
    164,074
    310
    Your Mercedes:
    The wires do break in the rear door hinge area you need to be sure that you have 12v getting to the door lock motor
  8. SteveCmerc
    SteveCmerc Member
    Oct 2, 2012
    Devon
    Your Mercedes:
    E270/2004/diesel
    Hope the hell it is not that.....Do you know which pins the 12V is on?
  9. television
    164,074
    310
    Your Mercedes:
    I will have to look that up
  10. television
    164,074
    310
    Your Mercedes:
    The fuse is F7 15amp
  11. SteveCmerc
    SteveCmerc Member
    Oct 2, 2012
    Devon
    Your Mercedes:
    E270/2004/diesel
    To get the latch motor out I need to disconnect the yellow and red air pipes to the interior handle. How to do ?
    Steve
  12. television
    164,074
    310
    Your Mercedes:
    I have the instructions that I can send you
  13. SteveCmerc
    SteveCmerc Member
    Oct 2, 2012
    Devon
    Your Mercedes:
    E270/2004/diesel
    Well I got it working by pulling Fuse 11 in the rear fuse bank (7 was the wiper motor, I think), cleaning and re-fitting. Keep kingers crossed it carries on......
    Thanks for pointer to check the the fuses before assuming worse case scenario.
  14. djcheung
    djcheung Senior Member
    64
    Oct 31, 2002
    Your Mercedes:
    03' E320 CDI
    Hi there,
    Sorry to resurrect a very, very old post.
    The problem just started on my 53' e320 cdi estate tailgate.
    The door will start get pulled in but it starts making noise half way in and then stops.
    I can still close the door by slamming it so the pulling action doesn't start.
    Does this mean a new lock or it can be fixed?
    Best regards,
    David.
  15. sehmbi
    sehmbi New Registration
    Sep 17, 2010
    could I have a copy too.
    To get the latch motor out I need to disconnect the yellow and red air pipes to the interior handle. How to do.
Share This Page
