w211 fan removal (to remove alternator)
Discussion in 'Electrics, Vacuum, Ignition and ECU' started by DY2, Nov 27, 2012.
  1. DY2
    DY2 Senior Member
    224
    6
    Sep 24, 2010
    Bexleyheath, Kent
    Your Mercedes:
    W211 2003 E320 Cdi Automatic
    While out the other night, the car dash lit up like an early christmas tree with a lot of malfunctions... Consumers shut down, Brake defective, ABS, ESP, SBC.... etc etc.
    The rear battery is a new install (less than 1 week) and the small battery in the engine bay is relatively new, when I had the SBC pump replaced a few months back.
    I tried taking the voltage reg. from the back of the alternator, rather than complete removal of the alternator, but, it seems one of the nuts has rounded off and I cannot grip it sufficiently to undo, and space is very tight. So complete removal has become the only option.
    However, trying to remove the darn alternator seems a challenge into itself, from abover too. I have removed the air filter housing and two pipes for the water pump, but i am struggling to get the alternator out of the tight space. There is very little room between the water pump, a electrical box? and a metal offshoot used for a bolt to the alternator... so seems to get a little bit more room, the only option is to remove the fan.
    Does anyone have removal process to get the fan out, please?. Im sure its not difficult, but.. :)
    [​IMG]
  2. mersum1es
    mersum1es Senior Member
    1,956
    229
    Sep 25, 2010
    Finland
    Your Mercedes:
  3. OP
    DY2
    DY2 Senior Member
    224
    6
    Sep 24, 2010
    Bexleyheath, Kent
    Your Mercedes:
    Thank you for the links.
    I had a go at the fan, and managed to get it out.
    The new alternator is in, and so far, looking good, with the rear battery sitting at 14.1v with the engine running :D
Share This Page
