W211 HID not working
Discussion in 'Electrics, Vacuum, Ignition and ECU' started by mollymac, Nov 5, 2012.
  1. mollymac
    mollymac New Member
    6
    Nov 5, 2012
    Reigate
    Your Mercedes:
    W211 /2006/ E320 CDI Sport
    I have a RHD ( UK based) 2006 E320 CDI sport with what I assume are factory-fit HID Headlamps. DS1 35w Phillips Bulb and Ballasts
    The drivers side dipped headlamp is off permanently. I have swapped the bulb and base unit ( I believe this is referred to as the ballast) with the working side but that still doesnt work so I have eliminated the bulb and base unit. I have tried locating the fuse but it doesnt show on the MB Fuse diagram. I then assumed the fuse would be located in the engine compartment fuse box ( as MB do not show that in their fuse chart) but all those fuses are Ok.
    Also the ballast unit on the non-working side does not locate within the headlamp unit with a solid twist and click as with the other side
    Can anyone help ?. Just so you know I am not that technical
    Thanks in advance
    Paul McG
    Molly Mac is online now Report Post Edit/Delete Message
  2. television
    television Always remembered RIP
    164,074
    310
    Your Mercedes:
    This could be the ECU control that has failed
  3. OP
    mollymac
    mollymac New Member
    6
    Nov 5, 2012
    Reigate
    Your Mercedes:
    Many thanks
    Would you happen to know where the ECU control is located and is it repairable
  4. television
    164,074
    310
    Your Mercedes:
    12 A 002 820 23 26 .CONTROL UNIT
    XENON CONTROL UNIT, LEFT [006], [007]
    Code: 614/618/615/616
    001
    12 A 211 870 88 26 .CONTROL UNIT
    XENON
    Replaced_By: A 211 870 90 26
    It could have one of these numbers, it could be in the headlamp or just under it if you follow the wires. these are very cheap on Ebay
    [​IMG]
  5. Troon
    Troon Active Senior Members
    917
    3
    Sep 16, 2011
    Staffordshire
    Your Mercedes:
    A big one
    The fuses covering the lamps are in the engine bay fuse box but all relevant fuses cover both sides.
  6. OP
    mollymac
    mollymac New Member
    6
    Nov 5, 2012
    Reigate
    Your Mercedes:
    Many thanks
    Valuable advice as many other non-MB HID systems seem to infer a fuse for each headlamp
  7. OP
    mollymac
    mollymac New Member
    6
    Nov 5, 2012
    Reigate
    Your Mercedes:
    Thank you very much for this. I will use my very limited Motor DIY skills and see if this cures my problem
  8. bigasotonuk
    bigasotonuk Senior Member
    5,243
    9
    Nov 14, 2006
    Southampton UK
    Your Mercedes:
    C43/55 AMG 1999 / C230K 1997
    As your ballast does not locate with a solid click/twist I would try the units from the duff side in the good side just to be sure where the fault lies, if then it doesn,t work the fault should lie in the ignitor box, which on other MB's is,nt replaceable as it comes as part of the headlight assembly and is located inside the headlight. Though not sure of the set up on the 211.
    If you need any Xenon parts for it take a look at this web site and drop them a mail of your requirements,
    http://www.oemxenonpart.com/OEM_Xenon_Part.htm
  9. OP
    mollymac
    mollymac New Member
    6
    Nov 5, 2012
    Reigate
    Your Mercedes:
    Many thanks Andy. I think this most likely the problem but I think a headlamp replacement is beyond my DIY skills. Looks like the MB dealer beckons
    Cheers
    Paul
  10. television
    164,074
    310
    Your Mercedes:
    If you need to remove the headlamp the bumper has to come off, I would avoid MB on this for they will just fit a new headlamp at £1k plus fitting
  11. Naraic
    Naraic Moderator
    10,330
    942
    Mar 4, 2010
    Your Mercedes:
    2005 CL500.
    Strange how a bill of £1k suddenly makes diy so appealing.
  12. television
    164,074
    310
    Your Mercedes:
    I am not sure of that price but it could be correct
  13. OP
    mollymac
    mollymac New Member
    6
    Nov 5, 2012
    Reigate
    Your Mercedes:
    Many thanks for anll your advice. It transpired to be a weather-beaten ECU unit ( as Television had stated)/ I used a very efficient mobile Mercedes service, Mercanix, that came the next day and fitted a refurb unit for 150.00.
Share This Page
