W211 MOT Emissions fail - next steps?
Discussion in 'Engine, Drivetrain, Fuel and Exhaust' started by gez, Aug 12, 2019.
  1. gez
    gez Senior Member
    104
    Dec 31, 2007
    South Coast
    Your Mercedes:
    W211 E320 CDi Estate, R129 Brabus SL500 (SOLD), R231 SL400 AMG Line
    My 2003 W211 E320CDI with the straight6 648.961 diesel engine has failed it's MOT on emissions.
    The average reading was 1.53 against a plate value of 0.6.
    I changed the air filter, though it didn't look too dirty, and added a bottle of Wynn's "Pre-emission test treatment" to the maximum strength they recommend (30 litres of diesel) and have thrashed it for 100+ miles, making sure it was well warmed up before it's retest.
    However, it failed the retest with an average only down to 0.85.
    I get my cars tested at the council depot so they do not offer repairs.
    The car has just under 100k miles, runs fine, no engine mgmt light etc., is fully serviced and is too good to scrap unless I have no reasonable alternative.
    What are the next recommended steps?
  2. Wighty
    Wighty Senior Member
    7,359
    4,436
    Aug 4, 2016
    Your Mercedes:
    Well , that improved massively . Maybe do the same again and if the improvement is the same the car will pass ?
    Mrtibbs, matthew k and Jim2 like this.
  3. OP
    gez
    gez Senior Member
    104
    Dec 31, 2007
    South Coast
    Your Mercedes:
    The guy did a second retest for me immediately after the 0.85. That averaged 1.1 so seems to vary.
    I could give it another go if recommended but I'm guessing there's something a bit more long term needed.
    Dainis likes this.
  4. LostKiwi
    LostKiwi Senior Member
    20,436
    9,994
    Aug 25, 2006
    Your Mercedes:
    '93 500SL-32, '01 W210 Estate E240, 02 R230 SL500 (Malcolm Spec), 04 Smart Roadster Coupe
    Sounds like it needs to go on Star and look at the live running values - particularly MAF, lambda and injection values.
  5. Tony Dyson
    Tony Dyson Senior Member
    1,274
    520
    Aug 26, 2018
    God's Country
    Your Mercedes:
    2014 C 220 CDI W204 OM 651
    Has the car been modified at all during it's lifetime?
  6. OP
    gez
    gez Senior Member
    104
    Dec 31, 2007
    South Coast
    Your Mercedes:
    No, nothing modified.
  7. Blobcat
    Blobcat Moderator
    17,424
    4,983
    Near Grange Moor (not Wakefield...)
    Your Mercedes:
    R171 SLK280 3.0, Land Rover 110 County SW
    No warning lights or limp home? (thinking MAF)
  8. OP
    gez
    gez Senior Member
    104
    Dec 31, 2007
    South Coast
    Your Mercedes:
    Nope, no EML, no other warnings or errors, has always run fine.
    It does mostly do short runs with only occasional longer journeys, so that probably doesn't help.
    The guy at the MOT center did say he was surprised that the plate value was only 0.6, but he showed me the sticker to confirm. He said many much newer cars have much higher manufacturers limits - up to 3.2, but clearly he cant change the target!
  9. Wighty
    7,359
    4,436
    Aug 4, 2016
    Your Mercedes:
    The car may well have fault codes that don't trigger a dash warning light or limp mode . Has the car been "read" ?
    My car had a faulty O2 sensor for ages with nothing on the dash .
    Jim2 likes this.
  10. Botus
    Botus Senior Member
    3,262
    676
    Jul 29, 2014
    Your Mercedes:
    S500/2010/500
    whilst we shouldn't condone running tractors with poor emissions, I expect any other MOT test centre will have no issues at all with it completing an emissions test.
    the only difficulty I can see is if the failures are recorded and a very keen MOT inspector was to follow things up, either way the problem would be with the testers and you'll be on the road....
    Wighty likes this.
  11. EmilysDad
    EmilysDad Senior Member
    7,961
    1,759
    May 8, 2012
    Bury Lancs
    Your Mercedes:
    ML350
    like putting the exhaust probe up another car's exhaust ...... :rolleyes::rolleyes:
    matthew k, Jim2 and Wighty like this.
  12. Wighty
    7,359
    4,436
    Aug 4, 2016
    Your Mercedes:
    Oooooo Mrs !:eek::D
    Jim2 and EmilysDad like this.
  13. V6Matty
    V6Matty Senior Member
    5,951
    894
    Aug 1, 2012
    Newark, Notts
    Your Mercedes:
    S212/10/E350(His) W169/2005/A180 (Hers)
    MOT for my car this year we couldn’t get it to do an emissions test, probe went in but there was so little exhaust gas at tick over it wouldn’t register so wouldn’t start the test.
  14. Wighty
    7,359
    4,436
    Aug 4, 2016
    Your Mercedes:
    :eek: ! Which car , and what happens next buddy ?
    Jim2 likes this.
  15. V6Matty
    5,951
    894
    Aug 1, 2012
    Newark, Notts
    Your Mercedes:
    This was with the 212, not much happens now, just gets registered in the MOT that a emissions test couldn’t be completed, nothing more than that
  16. Jim2
    Jim2 Senior Member
    846
    520
    Jan 18, 2018
    Your Mercedes:
    2010 Eclass w212 2.1 CDI
    Off, hand, anyone know what are the NOX emission's from the 2010 MB E class w212 with the 2.1 CDI engine?
    Wighty likes this.
  17. Gazwould
    Gazwould Senior Member
    661
    293
    Oct 28, 2018
    Your Mercedes:
    S204 OM651
    No need , VED is CO2 based and MOT for dervs is simply smoke opacity .
  18. bembo449
    bembo449 Senior Member
    3,831
    1,107
    Jan 2, 2012
    lincolnshire
    Your Mercedes:
    w221 320cdi , r170 23k , range rover vogue , insignia vxr , shitron dispatch
    did you give it an Italian tune up before you took it , I find when I get a customers car that I know is used for short journeys , I make sure I get it hot and give it a bit of stick to clean it out
    Jim2, Rob76 and Wighty like this.
  19. malcolm210
    malcolm210 Senior Member
    3,645
    660
    Aug 21, 2005
    Try some premium fuel and cetane enhancer (Millers) that might help as already said the car almost passed the second time. It might be that the inlet manifold needs cleaning they do sludge up especially with short runs leading to inlet port shut off butterfly valves in the manifold being stuck
    Mrtibbs, Jim2, Wighty and 1 other person like this.
  20. d215yq
    d215yq Senior Member
    2,191
    352
    Mar 28, 2008
    Barcelona
    Your Mercedes:
    1987 W124 300D 250k
    As a last resort (might cause engine damage on a CDi but unlikely for a one off and if you're considering scrapping it anyway for this fail...) you could just chuck in veg oil. Mine was once a borderline fail on opacity (the only test they do here) so just put 5L of veg oil in with a near empty tank for every MOT, and since then has been about 0.5 (before was 2.4, spanish limit 2.5, and only passed at 2.4 because the kind supervisor suggested i rev it to 1500rpm instead of 2500 rpm!) ...and yet I've done nothing to the car inbetween. Very noticeable on start up too how much cleaner the emissions are (you can't actually see/smell them!).
    You could put 5L in to a near empty tank a few miles before the test, and then fill it with diesel immediately after to reduce chance of damage.
    The emissions test is hard here because it's the last test after inching the car through all the others yourself in a queue, so the car has been idling for 45 minutes building up soot before the test is done. Perhaps make sure on the retest they take the car straight to the machine and it's not sat about restarted/idled for a while etc which could allow it to build up stuff after the Italian tuneup?
    Jim2 likes this.
Share This Page
