W211 Rain sensor
girota
USA
2007 mercedes E550 4 matic sport package
My rain sensor not working.I have small crack in the winshield like 2 inch in the driver side in the corner.
Have the windscreen replaced and ensure that the sensor is correctly setup when the new screen is fitted. Quite a few members have the screen fitted at a Mercedes garage by their insurance company so that when the windscreen company has finished Mercedes can check that the sensor is correctly setup.
jberks
Agreed - have your dealer sort it, they can arrange for the screen to be replaced and sort with your insurance, and can fix your sensor at the same time. It will need calibrating anyway so if you arrange the screen yourself you're still going to need to visit the dealer and then claim for the work which will be a pain, mch better to have the dealer organise it all. The dealer did mine - admittedly it was them that broke the screen but the new screen is fine and the sensor works perfectly.
DMBaker
Crick, Northants
C180K SE Coupe
C180K SE Coupe Rain Sensor
My rain sensor isn't working either - I have a star-shaped stone chip about 20 mm across in the low centre of the windscreen. Wil this cause the rain sensor to malfunction?
Many thanks
Hello and welcome to the forum.
As long as the stone chip is not near the little blue circle at the top, the screen should not affect it.
I would find an indie with STAR to pinpoint the fault
DMBaker
Crick, Northants
C180K SE Coupe
Thanks for the very swift reply...forgive my ignorance but what are 'indie' and 'STAR'???
DMBaker
Crick, Northants
C180K SE Coupe
Thanks very much - would they be able to help with another problem with my driver foldaway mirror not working? The passenger one works fine but there is no movement at all with the driver side.
Yes they will help wioth that,could be just a broken wire on that.
