W211 Rear Light Failures
Rez
2017 S213 e220d Premium Plus
Folks,
I've just bought a 2004 320CDI Estate and three days into my ownership I've got the following error messages appearing whilst driving or whenever I select :-
Right-hand Tail Lamp
Right-hand brake lamp
Rear right brake lamp, Back-up light on
Rear left brake lamp, Back-up light on
Left hand tail lamp, back-up light on
Right hand tail lamp, back-up light on
When I press the brakes all the LEDs illuminate and indeed the OS LEDs flash slowly. The tailgate red lights come on... Presumably they are the backup lights.
Trawling this and other forums it would appear I either need new light units with all the regular and LED bulbs hard wired on or I need to find a break in the cabling, or solder in some little chip... Either way not best pleased! :mad:
Any suggestions? Presumably the lights are maIn dealer items?
Thanks in advance
Rez
Not quite clear on this one, are all the lamps working
R
Rez
Jib, no towbar fitted.
Television, they are working intermittently. Today I got no fault messages all day then on they came late afternoon. I've just had the OS lamp unit out and apart... Right there in my hands it initially worked, then it stopped and then became the slow flashing high intensity light.
Very odd behaviour because clearly the LEDs are working in both low and high intensity modes, but somewhere in the circuit there's a fault.
I've read about the replacement of the IC chips... My soldering is no longer what it used to be... Time for a new LED circuit board from MB... Unless they can be bought as pattern parts?
I think the lamps only come complete. is it the lamps in the rear door
spenttherent
E220 Eclass estate 2008
I had the same problem
in the end I just bought a new light cost about £50 from MB
Smok
1968 MGC Roadster, 1972 Elan +2 130S, 2001 Ferrari 456M GTE320 CDI Avantegarde
Is that the back plate and the lens?
I've a 55 E320CDI with the exact same problem (right hand lights).
Is the light simple to swap over?
For that price it must have been
spenttherent
50 pound only got me the plate.....sorry to say :(
But it was only a simple job :)
