W213 Coupe side window not closing issue
IKik23
United Kingdom
W213 2019 220D Coupe
Hello,
About a week ago I have noticed the frameless windows which are supposed to sit flush with one another have got misaligned. The drivers side is perfectly fine however the in the passenger side the top of the window is sticking out, but the bottom is connecting perfect as well. I tried synchronising the windows by holding the buttons down for 5s but to no help.Anyone ran into this issue in the coupes and if so how did you manage to fix it?
Attaching pictures for reference, thanks!
B31BA2AB-E645-4862-AC2F-005FE96436E1.jpeg 9FF0E9BF-DE62-4E3D-931F-A779E2E1510F.jpeg
Larkone
NW Essex
C219 CLS 320CDI 2008
Looks like the window regulator has gone out of alignment - needs investigating by going into the door and seeing what has happened.
I
IKik23
United Kingdom
Thanks for the reply,
Since then i have undone the rear side panel and you were correct, the window just needed some adjustments on the regulator and all is working fine now.
Once again thank you !
anyweb
Sweden
www.niallbrady.com
c238,w120 (diesel)
in anticipation of it occuring on my C238 (which is the model you have), do you have any photos of where you opened up and what you adjusted ?
