W213: door clicks twice when opening or closing
Discussion in 'Bodywork, Tyres, Wheels & Trim' started by anyweb, Jul 22, 2019.
  1. anyweb
    anyweb Senior Member
    2,943
    213
    Jul 15, 2005
    Sweden
    Your Mercedes:
    c238,w120 (diesel)
    hi,
    when I bought this car it had this problem and it annoys me every time I open or close the drivers side door, basically you here a loud clicking like as if a metal plate is springing back against another, that clicks twice every time i open or close the door, all the other doors open quietly as you'd expect,
    I've looked at the W213 door hinges and they seem to be welded shut so i cannot see what is wrong or how to fix it,
    has anyone any ideas about what the issue is and how to fix it ?
    cheers
    niall
  2. EmilysDad
    EmilysDad Senior Member
    9,218
    2,744
    May 8, 2012
    Bury Lancs
    Your Mercedes:
    ML350
  3. OP
    anyweb
    2,943
    213
    Jul 15, 2005
    Sweden
    Your Mercedes:
    c238,w120 (diesel)
    i'm not sure, i think its the lower of the two hinges, i'll take some video of it today to show you where the sound is coming from, also i cannot see any way to lubricate it... it's not like previous models
  4. star
    star Forum Supporter Authorised Forum Supporter
    5,543
    986
    Oct 6, 2004
    Reading
    Your Mercedes:
    Smart + others :)
    No check strap, look for a small stub of a bolt, poss 6 or 7mm on the hinge and tighten.
    Srdl and anyweb like this.
  5. OP
    anyweb
    2,943
    213
    Jul 15, 2005
    Sweden
    Your Mercedes:
    c238,w120 (diesel)
    really ? can you tell me where in this photo that would be exactly, from holding my finger on the hinges when i open it i believe the clicking is coming from the bottom hinge..
  6. OP
    anyweb
    2,943
    213
    Jul 15, 2005
    Sweden
    Your Mercedes:
    c238,w120 (diesel)
    hi @star is the small bolt under the top or bottom hinge ?
  7. OP
    anyweb
    2,943
    213
    Jul 15, 2005
    Sweden
    Your Mercedes:
    c238,w120 (diesel)
    omg thank you @star !! I went out and tried with a 7mm and tightened the loose nut there under the bottom hinge (see photo), problem solved !!! no more annoying noise !!! thank you so much !
    Mujja, daibevan, star and 6 others like this.
  8. star
    5,543
    986
    Oct 6, 2004
    Reading
    Your Mercedes:
    Smart + others :)
  9. Paul Black
    Paul Black Registered
    Jan 27, 2020
    Your Mercedes:
    Mercedes e class 2016 e220
    Was searching for this and it works a treat cheers
    anyweb and star like this.
  10. Laois
    Laois New Member
    Saturday
    Your Mercedes:
    E220d
    I too have recently bought a year old w213 and since receiving it have found the drivers door is making the clicking sound and not always closing at first attempt.
    I have seen your solution above to tighten a 7mm nut on the lower hinge. I have tried this but it does not move. I am interested to know how much force you needed to apply to turn the nut? Was there a lot of resistance or very little?
    I am afraid of ringing the nut or threads and very interested to know of your experience and force required.
    Unfortunately with current Covid-19 restrictions it is not easy to get to MB dealer for them to take a look.
    Many thanks!
  11. OP
    anyweb
    2,943
    213
    Jul 15, 2005
    Sweden
    Your Mercedes:
    c238,w120 (diesel)
    mine was loose and didn't need much force at all to tighten. are you sure the clicking noise i reported is coming from your lower hinge
  12. Laois
    Laois New Member
    Saturday
    Your Mercedes:
    E220d
    Hm, thank you for confirming. The click in mine is not so loud so difficult to tell where it comes from. I feel the two pops more so. I have a 2017 that opens smoothly. Thanks anyway, perhaps I will need to wait to get access to the dealership.
  13. OP
    anyweb
    2,943
    213
    Jul 15, 2005
    Sweden
    Your Mercedes:
    c238,w120 (diesel)
    what i did was to put my finger tips on the lower hinge while moving the door open/close to see if i could feel the click, that was how i narrowed it down to the lower hinge, have you verified that ? the 7mm nut is below the line of sight of the hinge, so at first glance you won't see it (it's under the hinge from memory)
Share This Page
