W220 320 cdi heated rear screen.
Steve w220
W220 s class 320 cdi 2002
I have owned the car for a couple of years and love it it's always had rear windows that work when they wanted and a heated rear screen that never worked despite the switch illuminating for the correct time . So today I decided to check th e fuse under the rear seat and it was blown ,I replaced it switched it on and it blew straight away . Can anybody point me to a wiring diagram for the hrw or know if the relay would be the cause? Thanks in advance ,steve.
moj91
Northamptonshire
W213 E400d-T, W204 C250CDI-T, W220 S320CDI (AMG Kit), W168 A170CDI, W210&W124 OM606...
I know there is a module in the rear pillar behind the trim which was causing similar issues with ours (blowing fuses/crackling noise on stereo etc) but i cant recall anything further than that I'm afraid! :/
Steve w220
Thanks for that, I think I will pull the relay and check it hasnt gone to earth then work my way towards the rear pillar..
moj91
Northamptonshire
If you put your VIN into the website www.partsouq.com, you should be able to find a schematic of the pillar area and potentially offending module!!
www.ckinsurance.co.uk
