I have a 1999 w220 (one of the early ones) s320. The car is only at 79000 miles and great, except my aircon is broken
I had it re-gassed but no effect.
Though this was carried out a national tyre centre.
The engine changes revs slightly when I turn the air con on so I think the pump is okay, I have also reset the system on the climate control, removal of battery and also reset of the fault codes through a DBMS reader.
I wondered if the gas pressure from national was insufficient for the compressor to kick in, as I have read on some posts that the w220 system needs higher pressure than normal?
Or could this be the compressor? Just for additional info having read other posts, the belt seems to be fine and the compressor turns. The revs shift when the compressor comes in. However, there is no cooling whatsoever. Just warn air and on a hot day it is unbearable.... luckily we're into winter soon
Any thoughts on what I could check would be great, or if the pressure aspect could be the issue?
Thanks in advance
Thanks in advance
