Irresistance
- Apr 25, 2009
- Location
- Gdansk, Poland
- 2004 W220 320CDI
Hello,
Slightly annoying problem here on my W220. Since about 3 months or so, my Comand has been misbehaving. This started to occur after I bought (what is said to be) an orignal Nokia 6310i phone for the carkit. The phone works OK, rings, does SMS, shows on display, etc. - but ever since I have put it in, the following issues have started to occur:
1) Mid-music radio decides to restart. Screen goes black with music abruptly stopping. Restart will take about 5-10 seconds and then it acts like nothing happened. Sometimes it will revert back to the last known channel, sometimes to some 'default' selection (so you can tell it indeed actually CRASHED and did not store running values).
2) It will hang. Just sit there. Sometimes music continues, sometimes it becomes silent. Just... yeah. And then it will take up to two minutes before it either self-resets, or I have to reset it myself. Interestingly, it does seem to remember my button presses, so it will go on and off again coz I hit "on" twice.
3) When I have the entire unit switched off, now and again (rarely, about three times in the past 3 months) it will switch itself on (screen will come on with the nanny warning, but no sound/music) and go off again. Yeah...
4) Once in a particularly foul mood it actually restarted 2-3 times in a row until finally settling. I would say that this last month the type of problems have become more severe - first it was just restart and continue, now it also hangs more and generally appears very unhappy...
Now - this also happens with the phone NOT in the car. So its presence is NOT required for these random acts of insubordination to take place. It also does not appear that its presence increases the severity or frequency of misbehavings.
Thus, the phone thing might be a coincidence. Before the phone I believe this has happened only once or so (volume was gone for no reason) but only after using the phone in it, has it become a serious problem. Sometimes I will be driving 500+ miles and it will work fine, sometimes it crashes three times over the span of 30 minutes. It seems completely arbitrary. The only semi-hunch I am having is that it seems that it tends to crash when I do something, anything, electrical (indicator, switch C/S switch on gearbox... anything really) but I think this is just coincidence.
Will STAR tell me what is going on with the unit? Do I have some sort of general electrical problem that tortures the Comand unit?
The only other "electrical" issue I have had (first time and only time) is a SRS warning about a week ago, but I suspect that is either some sensor or a loose connection. Aside of this, nothing electrical/CAN-related appears to be going on, and the vehicle works fine.
Oh and last but not least... about a month ago (so in the middle of this whole saga) I have actually disconnected and reconnected the battery, and this did nothing. If anything, it's made things worse (see point 4).
