W220 flashing!
hotgjc
W220 S350
Hi all,
After recently acquiring a 2003 S350 I'm finding that sometimes [and only sometimes] when locking it the indicators flash continually rather than the three times their supposed too, then unlocking and re locking the indicators flash three times as normal, only a little thing I know but still a little annoying. I had a look through the handbook to no avail. Any suggestions gratefully received.
Dash1
No longer a forum member
Hi all,
Hi hotgjc,
It sounds very much like to me as though your alarm system (located under the n/side front wheel arch liner near the passenger footwell) is in its infancy of imminent failure. Classic signs of the circuit board being contaminated by leakage from the internal NiMH battery. Unfortunately, like every type of secondary battery, they eventually deteriorate and leak over time, and in this instance, damaging the PCB within the alarm unit
You could possibly wait and see if it deteriorates any further or have it checked out by a competent auto electrician. I had my alarm unit replaced on my CL last year for very similar reasons – if unchanged, then over the subsequent coming months the alarm will start to go off on its own.
Best Regards,
Dash1
AdamG
Bromley, Kent
S320CDI (2003)
My 2003 s320cdi does exactly the same. If the locking button is not pressed within a short time of all the doors being closed it goes into this optical alarm mode.
I have changed the siren and checked it using star but never got to the bottom of it.
I'm sure it is not supposed to be like that as it is annoying.
Adam
AmoS500
SLK250 R172
Hi, Would removing relay (P) for the horn, temporarily disable the horn and hence stop the flashing?
Not the horn, and nothing much to that circuit
AmoS500
SLK250 R172
Hi, If u replace the siren/horn, do u need a Star to configure the new one, or is it just a straight replacement?
