markben
- Feb 12, 2017
- Location
- Bristol UK
- w220 2004 S320L CDI
Greetings to all here. Apologies for this long post but you might understand why...
I haven't bored the daylights out of you
recently
about my long running 'mystery' Hard Damping 'HD' problem (always in Comfort mode) but someone here might be able to help?
The background & symptoms in brief:
long standing HD / too stiff / very harsh ADS damping invariably, but with rare, brief 'softening' ('Magic Carpet' - as it should be) in sudden colder weather. Various Indies (no names mentioned) have replaced all 4 Struts, ECU, Compressor, sensors etc etc with brand new OE at massive cost £££. But.. never any fault codes on SDS & the usual verdict is 'it rides ok'. Mmmm...
A recent new Indie (#6) has driven 'The Limo' (my otherwise immaculate & well maintained 2004 S320L cdi) over rough roads and agrees about the HD problem compared with similar W220s he knows. That's a good start and reassures me that I'm not 'imagining' the HD problem - as one indie politely suggested.
The latest Twist:
New indie reports that the car has factory fitted 'sports suspension' according to option code 674 on his database (correct VIN provided / screen shots of his readout sent to confirm). Therefore, he is certain / the data explains why the car rides 'as it should', i.e. stiffer than standard spec. and with no faults on SDS. Mmmm.. ?
BUT..(!) on my / the car's original data sheet, option code 674 refers only to '17" 5 twin-spoke alloy wheels + wide tyres'. NO mention of 'sports suspension' for code 674 nor anywhere else on the data sheet. Also, NO mention of code 647 'sports suspension' as a factory option anywhere else - including in the original sales brochure, on W220 ee. Wikipeadia etc. That's the Puzzle.
And.. W220s already have Airmatic / ADS with switchable Comfort & Sport 1 / 2 modes as standard equipment. So, by my logic, any references to, or claims about factory fitted 'sports suspension' are either due confused terminology on the Mercedes database / EPC or for some other reason? Mmmm.. again.
Through this HD saga (& despite the latest indie's verdict), my best guess is still that there's a 'hidden' fault in the ADS circuitry which is causing the HD problem. You tell me?
If you're still following this, you deserve a medal. But seriously, all thoughts & comments will be much appreciated.
Many thanks for following.
Mark B.
'The best or nothing'
The latest Twist:
Mark B.
