W220 Plenum chamber unblocking pictures
Joseph Brown
Uk
W220 2003 320cdi
Having just checked the plenum chamber on the W220 low and behold the drainage hole had dead leaves partially obstructing it. There are numorous references for the need to do this on the net, but below I quote Honest John from his review linked below;
"VITAL to keep ventilation plenum chamber drains clear of debris, or water overflows wetting carpets, vent blower motor and wiring loom causing shorts and sometimes necessitating a new loom. (The ventilation plenum chamber is the well in the bulkhead beneath the grille in front of the windscreen through which fresh air enters the car. It's open to the elements, so rainwater should flow freely through it, but won't if the drains either side are blocked. If that happens the rainwater will have nowhere to go except into the car.) Edit: And this is into the passanger footwell where the wiring loom is. :shock:
If buying used, CHECK ALL ELECTRICS and feel for damp front footwell carpets."
http://forums.mercedesclub.org.uk/newthread.php?do=newthread&f=5
Please see below for pictures and explanation of completing this easy task that took 15 minutes.
1. Locate the plenum chamber at the passenger side engine bay near the window
2. Remove the grate with a medium screwdriver by gently prising open each of the six slots in turn around the grill and pulling up slightly on the grill to release it on each occassion.
3. Inspect the drainage hole for blockages and remove them.
4. Replace grill and press down gently on each of the 6 catches to secure.
Job done :)
Cole@MBS
www.mbssouthampton.co.uk
MB's recall on this was to drill a 1 inch hole in the side case, long forgotten now days!! good to remind S class owners!!!
Oarsman
Norfolk
W221 S350L CDI Bluetec, Range Rover Vogue SE 4.4 TDI, 1963 Triumph TR4
Hi Joseph, this is a regular thread on the forum with people complaining of wet carpets in the passenger footwell.
It's good to see a pictorial "how to" though.
A picture's worth a thousand words.
The Admins may even put it up as a sticky.
drdre78
london
mercedes c200 200
hi it should be check on B service.Also mercedes still have this problem on new cars
