W220 rear inner window seal replacement help
m3gt2
Leicestershire
'68 E220 estate Premium Plus, Command Online with Virtual Cockpit, soft close doors and full ceramic
Hi, I need to change the seal that runs around the to of the glass/door frame. Would anyone be able to provide the WIS please as I am sure i will need to remove the door card and switches. The part is 2207350325 which I already have. Many thanks Chris
Is it 20 in the link
m.mycat
m3gt2
Leicestershire
Hi, many thanks for the super quick reply. I do already have the seal, I thought WIS told you how to fit it? That's the bit I'm not sure of!
Thats Ok I want to know if it is that part in the link I put up, if so you just pull it out and push the new one in by putting both ends in the correct place, then work the rest into the channel
m3gt2
Leicestershire
Brilliant but do I need the door card off as the seal is going to go below the lowest part of the frame? Thanks
You just push it down as it only goes to the top of the glass when its down.
No door card to come off
m3gt2
Leicestershire
Thank you so much for your help, don't think I would have tried it without your help!
