W220 S-Class Door Sill
dchotai
Hello, Sorry if this is in the wrong place. I have 1999 W220 S-Class and want to know where I can find the seal between the drivers side window and the door. Its a double glazed window if this helps. Any help would be greatly appreciated.
D
D
dchotai
Thanks for your help, I cant seem to tell which exact part it is any ideas?
Do you mean the rubber that goes along the bottom of the window opening that clips onto the door and rubs against the glass as it goes up and down
D
dchotai
Hey mate, I mean the one at the top of glass, the sill thats between the door and the curved part of the glass. Thinks its worn out through opening and closing so much!
Thanks again for your help malcolm
I think that you mean the window channel, its all in one lump that goes up both sides and along the top
Why not activate your Email in your user CP and I can send you a picture
D
dchotai
Yeh sounds right to me mate, just updated it now is that ok?
Thanks and sent do you mean20 in the picture
D
dchotai
Cheers Malcolm it is mean20 any ideas where i can get this part from?
Why not pull it down from the top, get a tube of impact adhesive (evo stick) apply it, push the rubber back to get the glue onto the door frame, pull it down again let it dry 10 mins and push it back up, and close the window.
You can replace it,it comes from MB only, and just a push fit
