kheath74
- Nov 10, 2008
- W124/1989/300CE
I have had a few strange issues with the Air Con today, I had lent my S320 CDI 2002 to my boss, dont ask, and when I drove it later he has set the drivers air con to manual, I noticed that the drivers side blowers were fully open and very hot air was coming out. I set the drivers air con to auto and then my feet started to get very hot.
I checked the centre vents and these were correct, set to 20C and felt the right temperature, meanwhile my drivers side is blasting out hot air. I have managed to get things back to normal by setting the drivers side to manual, lowering to LO and then setting back to auto and raising to 20C again.
Now I have the right temp from the vents but the AC OFF button light is always on, pressing it doesnt change the setting. The manual states I need to see MB and from reading the stickys it looks like I may need to regas the air con or the temp sensor has failed.
I did notice while I was driving that when I floored it the heat out of the drivers vents increased to very warm again and the engine temp raised to around 80 from around 60-70. Flooring was maybe 10 seconds from 40-70.
Thing is all was well until my boss borrowed it, but I dount he could have knackered it up that much but then again.
Any ideas on what I can check or am I due a visit to a dealer for a look at the air con?
Cheers
Cheers
