W221 fuse plan
tode
NW FRANCE
S350 btec 2011
Fuse plan for a 2011 S class (350 CDI Bluetec) . . . may be of help one day.
I really need this chart but can't see anything on it. Could you please email it to me valdleonid@gmail.com
You can zoom in, press the Ctrl button on your keyboard and move the scroll button on your mouse and you can zoom in or out.
tode
tode
NW FRANCE
S350 btec 2011
Leonid, have just mailed you with the original scans.
I posted using Photobucket, and for some unknown reason, they reduce the size and quality of the images. If you still have a problem, post again, and I'll try to find a way of posting larger images.
Leonid
Toronto
s500/2010
Tode. Thank you again for your email.
I was looking for a way of disabling headlamp washers and couldn't find that fuse on these pictures. If anybody knows where is it, I will be really grateful.
wywywywy
Registered
S500 2007
Sorry for bumping this old thread, but is there a higher resolution one available please? Because it is very difficult to read even when zoomed in.
Have you checked in the tool kit or in a fuse box to see if the fuse diagram is folded up in side
tode
tode
NW FRANCE
S350 btec 2011
I can mail it to you if you like. (Tried Imageshack as well, and it's still reduced).
tode
tode
NW FRANCE
S350 btec 2011
Here's the fuse list, split in two - better resolution.
HTH
Botus
S500/2010/500
http://merc-3bde.kxcdn.com/wp-conte...e-box-location-engine-interior-trunk-dash.pdf
  • Prefuse Box in the Engine Bay – F32/3
Fuse Number Ampere Rating Designation
F2 400 Alternator
F3 150 Electrohydraulic Power Steering A91/1 or glow time out put stage N14/3
F4 Nofuse Interior prefuse box F32/4
F5 100 AAC with integrated control additional fan motor M4/7
F6 150 Front SAM control unit with fuse. Relay module N10/1
F7 40 ESP Control Unit, Brake System
F8 25 ESP Control Unit, Brake System N30/6
F9 30 Front SAM control unit N10/1
F10 – Not used
  • Relays in Box in the Engine Bay – Front SAM Control Unit – N10/1
Fuses Engine Bay – Driver Side N10-1 Front SAM Control Unit
Relay Purpose
A Air Pump Relay
B Air Suspension Compressor Relay
C Engine terminal 87
D Relay 15 -terminal
R Terminal 87 relay
F Horn Relay
G 15R Relay
H Starter – Circuit 50 relay
J Starter – Circuit 15
K Wiper park heater relay
  • Fuses – Box in the Engine Bay – Front SAM Control Unit – N10/1
F20 10 Control Unit N3/9 or N3/10
F21 20 Circuit 87 – Fuel Pump Relay
F22 15 Connector sleeve
F23 20 Rear SAM Control Unit Fuse Box
F24 25 CDI Control Unit N3/9
F25 7.5 Instrument Cluster – Dashboard
F26 10 Left headlight – lamp unit
F27 10 Right Headlight – lamp unit
F28 7.5 EGS Unit Transmission control unit.
F29 5 Rear fuse box and relay module Rear SAM N10/2
F30 7.5 Fusel System Control Unit , Engine Control Unit N3/9 N3/10 N118
F31 5 Refrigerant Compressor
F32 15 Transmission oil pump control unit N89
F33 5 ESP Control Unit, Battery Management, Power Electronics
F34 5 Braking System N30/6
F35 5 Electric parking brake -A13
F36 10 Data link connector – 16 PinX11/4
F37 7.5 EIS Control Unit N73
F38 7.5 CGW Central Gateway control unit, Audio, Sound
F39 7.5 Instrument cluster
F40 7.5 Upper control panel N72/1
F41 30 Wiper motor M6/7
F42 30 Master wiper motor M6/6
F43 15 Front cigar lighter with ashtray illumination
F44 – Unused
F45 5 Power electronics pump M13/8
F46 15 ABC Control Unit N51/2 or AIRMATIC N51
F47 15 Steering column adjustment motor up or down
F48 15 Steering column adjustment motor in / out
F49 10 Steering column N80
F50 15 AAC Unit N22/1
F51 5 COMAND Display
F52A 15 Horns
F52B 15 Horns
F53 – Unused
F54 40 Air Recirculation AC
F55 60 Electric Air Pump
F56 40 AirMatic Compressor Pump A9/1
F57 30 Wiper Heater R2/10
F60 5 Power Steering A91-1
F61 7.5 SRS Airbag Restraint System N2/7
F62 5 Night View Assist N101
F63 15 Fuel Filter Sensor B76/1
F64 10 NECK PRO Head Restraint Solenoids Y24/12 – Driver, Y24/13-Passenger
F65 15 Outlet in glove box
F66 7.5 DTR Unit A89
  • Interior Fuses – side of the dash, F1/6
F70 40 Door Control Unit – Right N69/2
F71 15 Keyless Go Control Unit N69/5
F72 7.5 Pyrotechnical Separator K88
F73 5 Emergency Call System Control Unit
F74 30 TLC Control Unit
F75 10 Battery Management
F76 15 Vacuum pump relay
F77 50 Sound Amplifier A2/13
F78 25 AdBlue Relay/ Additional Fan/ Charge Air Cooler Circulation Pump
F79 7.5 Alarm H3/1
F80 40 Door Control Unit – Left Door N69/1
F81 30 Rear control unit CL model Rear door control unit S Class
F82 30 Rear door control unit
F83 30 Intellignet Servo Unit. Direct Select
F84 20 Sound Proceeding Unit A2/69
F85 10 Illumination for Door Sills
F86 – Not used
F87 – Not used
F88 – Not used
F89 – Not used
F90 20 Heater unit
F91 5 Front SAM unit
  • Interior Fuses - Drivers side of dash, F1/7
F92 40 Left front seat N32/1
F93 7.5 Weight sensing system N2/13
F94 5 Camera
F95 – Spare
F96 5 TPM RDK Unit N88
F97 7.5 DVD Player
F98 – Spare
F99 7.5 COMAND
F100 5 Media Interface N125/1
F101 10 Rear Displays Left A40/5 RightA40/6
F102 40 Right front seat N32/2
F103 7.5 ESP Electronic Stability Program
F104 40 Audio Radio Tuner
F105 – Not used
F106 5 Navigation / TV Tuner/ Toll Collection
F107 5 HD Tuner N87/8, Audio Broadcasting N87/3, SDAR Sirus Unit
F108 5 Rear A/C N22/4
F109 15 Rear Air conditioner blower motor N29/2
F110 7.5 Rear Back rest control Unit N32/20 N32/21
F111 5 RCP Control Unit N72/2
F112 5 Fuse box, Front SAM
F113 5 DC Converter
F114 – Not used
  • Prefuse Box Hidden behind the dash, passenger side. P32/4
Fuse Location Ampere Rating Purpose
F3 150 Rear SAM control unit N10/2
F4 150 Heated Windshield, DC Converter, ECO start/stop function
F5 40 Vacum Pump
F6 80 Right dashboard fuse box F1/6
F7 150 Heater booster R22/3
F8 80 Front SAM module N10/1
F9 80 Left dashboard fuse box F1/7
F10 150 Rear SAM N10/2
  • Battery Fuse – Backup – F38
Fuse 38 is a 5-ampere fuse, for the additional auxiliary battery G1/7, EZS control unit N73, and Front SAM control unit.
  • Fuses in trunk – Rear Sam Control Unit – N10/2
Fuse Ampere Rating Designation
F115 50 Rear window heater
F116 10 Power electronic pump
F117 15 Rear cigar outlet
F117 30 Fuel Pump
F118 15 AC Compressor/ Power electronics pump/ fuel pump
F119 7.5 Front central unit A40/9
F120 – Not used
F121 10 Audio radio tuner
F122 7.5 COMAND A40/3
F123 40 Emergency tension retractor – Right front A76/1
F124 40 Emergency tensioner retractor – left front A76
F125 5 Voice Control VCS N41/3
F126 25 Overhead control panel N70
F127 30 Pneumatic pump seat control M40/1, Seat pneumatic pump M40, Lumbar pmp M25/1
F128 25 Fuel pump N118
F129 25 Universal portable cell phone control unit UPCI N123/1
F130 30 Parking brake – Electric A13
F131 7.5 Rear window antenna amplifier A2/12
F133 5 Rear camera B84/3
F134 15 Rear trunk outlet socket X58/12
F135 7.5 Radar sensor / parktronic PTS N62
F136 7.5 AdBlue N118/5
F137 7.5 Rear Camera B84/3
F138 5 TV/ tuner / emergency call / navigator
F139 15 Rear back rest refrigerator A39/1
F140 15 120 outlet socket, rear cigarete lighter outlet
F141 5 Rear camera N66/2
F142 7.5 Video and radar sensor N62
F143 25 Rear seat N25/6
F144 25 Rear seat N25/6
F145 20 Rear trailer hitch socket – 13 pin type – X58
F146 25 Trailer N28/1
F147 – Spare
F148 25 Panoramic sliding sunroof
F149 25 Panoramic sliding sunroof A98
F150 7.5 TV Tuner
F151 20 Trailer
F152 25 AC Converter from DC N24/3
F153 – Not used
  • Relays in trunk – Rear Sam Control Unit – N10/2
    Relay Purpose of relay
M Circuit 15 N10/2
N Terminal 15R
O Power outlet relay
R Cigar lighter relay
S Fuel Pump
tode
tode
NW FRANCE
S350 btec 2011
S350 FUSIBLES 2011b 01.jpg And for the fuse locations:
the director
Bristolshire
2010 R 350 Grand Edition; 2015 S 350
Don’t spose you’ve got similar to show the location of the auxiliary battery? Mine’s malfunctioning and I think it’s behind the dash somewhere.
wywywywy
Registered
S500 2007
Is yours a facelift model? The facelift only has 1 battery I think.
John Laidlaw
Wirral
Land Rover Discovery 4
Don’t have a chart or pdf but that is indeed where the battery is apparently- behind the fuse box on drivers side dash
tode
tode
NW FRANCE
S350 btec 2011
  • #17
The auxilliary battery on mine (a 2011) is in the boot, behind the panel between boot and rear seats.
www.ckinsurance.co.uk
