W245 B Class SRS reset, following taking seats out?
Dasauto
Cirencester
B280 Sport/2010/2lt Diesel/Auto
Hi, Took my driver and passenger seats out to clean and repair. Now reinstalled I have a SRS fault code. I’m fairly sure this has been generated while the seats were out. Now everything (seats etc) is back in place the code is still there.
I’ve read something somewhere that even is everything is back in and working the SRS code will stay until cleared with a scanner.
Can anyone comment on this?
Also read a icarsoft i980 might be able to help with SRS scan and reset.
Correct on all counts. ;)
I removed my seat for repair & had the same fault as you, however I already had an iCarsoft that successfully reset the warning.
Dasauto
Dasauto
Cirencester
Ta, thanks for commenting.
Dasauto
Dasauto
Cirencester
Just for info....
I tried an icarsoft i980 and it worked a treat.
Read the codes.
Cleared the codes.
All errors where do to with short circuits and high resistance detected to the seat belts and seat airbags while the connections where unplugged.
Regards, James
Full list of fault codes;
900B - the component or signal line to the component s88 / 2 (passenger seat belt buckle and seat belt warning switch) has short circuit to battery plus or open circuit
9022 - There is a fault in communication with component B48 (passenger seat and seated seat recognition) or there is a line error
9223 - the resistance in the ignition circuit with the component r12 / 20 (front left side airbag ignition pill) is too high
9243 - the resistance in the ignition circuit with the component r12 / 21 (front right side airbag ignition pill) is too high
