W245 B180 CDI Handbrake Adjustment
littlemosslad
Glossop, UK
B-Class/2006/180CDI
Hi fellow Mercedes owners! I have a question for our more mechanically experienced friends: How is the hand brake adjusted on a W245? Is it on the callipers or is it under the car somewhere? Any guidance would be gratefully received!!
Many thanks, Dave
WG M-B
North west london
C63 Wagon in black
There are manual adjusters for the brake shoes which can be got at with a screwdriver through the rear bolt holes once the wheels are removed.
The cable adjustment is above the rear axle. There is a 10 mill locknut which needs to be cracked first
stewartw
In the picture below you can just about see a spring and a cog next to it, you need to turn this to tighten it or loosen it, but you'll have to do it with the rear disc in place so you won't be able to see it.
Once the disc was in place I just shown an led light into the bolt hole and turned the disc until I cold see the cog, then used a flat head screw driver to turn the cog until the disc would not turn, after this i undid it by 2 flicks until the disec could turn freely.
My previous thread of changing the rear disc & pads.
http://forums.mercedesclub.org.uk/showthread.php?t=90148
Hope this helps
L
littlemosslad
Glossop, UK
B-Class/2006/180CDI
ahhhh
ahh so there's a brake shoe within the disc hub? I'll have a look thanks!
Dave
L
littlemosslad
Glossop, UK
B-Class/2006/180CDI
yeah i actually saw your previous post and got confused because of the shoes inside the disc thing, i've never seen that before!
Thanks for laying that out for me, i'll have a good look.
cheers, Dave
L
littlemosslad
Glossop, UK
B-Class/2006/180CDI
cheers!
Hi, thanks very much for the advice. I've finally got round to doing it and it worked a treat. Bit fiddly but great!
thanks again, Dave
steve hw
Norwich, Norfolk
180 cdi 2008
Anyone have info on replacing heater plugs (glow plugs) on 2008 b180 cdi
Sorry to add on to this thread but not sure how to start a new thread. thanks
