mioba
- Feb 19, 2006
- Location
- Nottingham and Köln
- W124/E200, W220/S320CDI, W205/C200, W251/R350CDI 4Matic
So for the last few months the rear door on the beast has been tempremental. Sometimes opening half way and rarely closing with the internal switch on the rear door.
So out with the icarsoft - anti pinch strips - short.
I had been putting it off as not major, but being OCD got round to doing it today.
The strips on the W251 are part of the complete trim either side of the rear door seal and run from the hinges down the sides to the rear lights. Which makes them ****** expensive.
4 screws in total torx 25 (one under a buffer) and a push grommet at the top. Need to access the rear light panels to undo a purple wire clip thats fed through a rubber grommet.
There is a wedge at the top of the APS, make sure it sits behind the metal work and the top end slips inside a recess.
Clean the bodywork before refitting.
You will need to lift the rear door seal around where the APS is.
Also put a bit of gaffa over the grommet for the wires to keep more watertight.
Each side took no more than 20 mins and wallet is much lighter
