W639 113CDi engine management light
Badger1965
Vito 113CDi
Hi folks, anyone up to speed with engine control diagnostics?
My Vito was running perfectly, no warnings or fault codes, but had a bit of "black death" building up around the no.2 injector. I took it all apart, cleaned everything, put it back together and it now runs great with no leak.
But......
I now have the EML on and stored code P2150, which according to my Launch Pro diagnostics is "power supply injector Group B short circuit to ground". Other variations of this fault code are listed on the internet as "Injector Group B voltage low" and "Injector Bank 2 circuit voltage out of range".
I can reset the fault code (either with engine running or stopped), start the engine immediately - before the ECU powers down - and all is good. The fault/code does not return whilst driving. However, if I wait with the ignition off for long enough that the ECU fully powers-down, the code re-appears instantly. The ECU seems to be picking up a fault whilst carrying out it's POST (Power On Self Test) cycle.
I have checked the voltages at the injector harness plugs (plugs disconnected, ignition on) and cylinders 1, 2, 3 & 4 all have 2.54v on the left (tall) pin, but the right (short) pin on cylinder 2 is showing 2.88v, whilst 1, 3 & 4 are all 0v.
I did have to use a second battery with jump leads to get it re-started after doing the injector seal, but surely the system ought to be designed to cope with this? I really don't want to condemn the ECU as that will undoubtedly be "arm & a leg" money, but it's looking that way......
Anyone offer any help please?
Thomas0111
Sprinter CDI316 2011
Hey! I have got the same problem problem after fixing black death on my sprinter 316 2011. Both injector 3 and 4 was leaking, so now I have low voltage on both group an and b.
How did you solve it?
davor1
New Registration
Vito 113cdi
Have you guys solved it as I'm encountering same problem
Thomas0111
Replacing the electrical connectors halfway solved my problem. I after that I still had one injector group with low voltage. I was then advised to try to add injector cleaner to my fuel tank, and after almost emptying my tank, it solved my problem. It came back after a few months, so I added injector cleaner again and the problem has not returned since.
