Warning..."ABC Visit Workshop"...CL500 2000
Mikesmerc
Co.Cork IRL
2001 CL500,1990 560SEC, 1988 230E, 1982 250, 1979 280CE, 1977 200D, 1972 350 SL, 1965 220S Fintail
Hello all, started my car this morning to let her warm up and defrost, left it at idle for ten mins, when I went to take off the above warning appeared, just as I left my drive way i noticed that the car had risen to its highest setting, couldnt go faster than 30mph as it felt like driving a bouncing castle. Had to pull in a mile down the road, tried pushing the level switch but to no avail. Shut it down and she dropped back down, restarted and warning apperaed that it was too low, pressed the reset and has been driving all day fine so far.
Any ideas guys?
thanks
Mike
drmw
Yorkshire
www.autonomed.co.uk
went through similar with my SL55 - turned out to be the dual pump - was not pushing enough pressure so the valve block decided to lock - took quite a bit of finding (main dealer at that) but new pump cured it.
Not a cheap repair unfortunately so hopefully it might be something less on yours
Mic
Oxfordshire
www.bennettgibbons.co.uk
Same as that
Mic
Stocker
Ashford, Kent
(W215) CL500.... GONE. (W212) E63s
Had similar but just the rear lifted to max "it is very disconcerting" as with yours it leveled out as was then ok, turned out to be a valve block which wasn't closing properly, my indie carried out a " rodeo " and changed the pump filter after doing so found miniscule particules in the old filter. Conclusion was that one or more of these had stopped the block closing as they are electromagnetic cr&p is attracted. Good as gold since.
HTH
M
Mikesmerc
Co.Cork IRL
Thanks guys, has been fine since I posted this, too near xmas to fork out for expensive repairs:(. A filter change wouldnt hurt, might just do that and hope for the best.
Rgds
Mike
I would not worry just now at all, most of these cars can do funny things, never for the fault to return, it had to be a sticky valve somewhere.
A fluid change would certainly do no harm along with any filter.
