joderest
- Apr 16, 2018
- ML270 2003
I think i posted this last year and got no luck.
last year i had a water leak in the ML270, passenger side, runs down from behind dash and exits by little light under dash. I sealed everything i could find, and the leak stopped.
Its happened again this year, i wonder if something contracts in the cold opening up a leak.
This time i am sealing bits one at a time to see which one stops the leak. I have slightly extended a drain channel under the bonnet, so water does not run down where the electrics enter the car, also put some seal round the grommet there, but still have a leak.
Next is wheel off and arch liner out to seal where drain hole runs out, there is a grommet there that seals up where the sunroof drains would be if vehicle had a sunroof, which it does not.
Anyone have any suggestions ?
