wireman
- Sep 20, 2005
- Location
- lancashire
- nice 201 2.5D 1993 & very nice 129 SL500 1994
It will (or at least should) pressurise and this pressure should try to blow the cap out of your hands and scald you even at 80C.
I would not expect the pressure to rise to the caps blow off pressure but would expect a couple of hundred millibars at 80.
Thats why there is a warning about not taking the cap of a hot engine on the tank and in the handbook.
If you must remove the cap hot turn it only a little, sufficient to release the pressure before you turn it fully and lift it.
Perhaps you could adapt your old cap to carry a pressure guage if it is still of concern that the system is carrying to much pressure, expect 100 - 500 millibars.
Best bet is change all your hoses (at least the fat radiator ones, the parts of the heater hoses nearest the heater may be a shade awkward to access), flush the system with a good two part cleaner (active & neutraliser) follow the instructions, rinse it all out then put a stat in, refill with 40-50% antifreeze/inhibitor to finish the job properly, check it daily for one week (cold level) and if all is OK call it sorted.
Don't put anything into the coolant other than antifreeze/inhibitor anything else is just bodgeing it, replace the coolant at 2-3 year intervals.
