Water problem??
StuggyZX10
I have changed my water pump on my E300TD 1999 recently and it has still been loseing coolant somewhere...i have noticed that the coolant is being forced back through the Expansion bottle cap for the radiator, i checked the cap and it seems okay but i have ordered a new one from Merc...is there anything else i could check/change to solve this...could the thermostat be at fault?? not opening....any help or suggestion would be appreciated thanks
rpe2
Silchester
Ask a garage to put a CO2 detector under the rad cap, will rule out a duff head gasket.
StuggyZX10
that will be next port of call i think.....thanks
wireman
lancashire
Old caps do develop slow leakage, due to the rubber washer going soft.
With luck replacing the cap should fix it or at least help.
grober
Scotland
W204 C200cdi estate
Did you have a "water pump incident" when it failed i.e. did the engine overheat/ If so sorry to say this might be CHG failure.
Or water pump as 230K posted elsewhere,,with the thermostat off you can check
StuggyZX10
No the car didnt overheat at all when i changed the pump it was okay at 80c temperature, it was grumbling and i did feel a little water from the pipe underneath the pump and just assumed my water leak was being caused by the pump failing as my car has done 160k and it looked as if it was still the original pump...but it seems the water was leaking back through the expansion bottle...i then changed the thermostat from the original complete unit after some good info from Television and got the new seperate housing and thermostat from merc and fitted this last week but it still has not cured it...pipes at the top and bottom are hot after a drive up to temp 80c on dash but do feel solid full of high pressure and when i do try and release this through unscrewing cap carefully it seems very excessive...when cold the pipes return to normal soft feel and can be squeezed although the top one feels empty...i cant think of anything else to try i have taken of thermostat and blown through pipes to check foe any blockages etc ....i have a new cap on order so if this dont fix it it looks like i will have to put it into merc or a descent independant.........it has been suggested the head gasket has gone..no water in oil and no white smoke from exhaust i can notice it has me stumped...unless as a friend suggested the water pump is faulty how can i test it without changeing it no water is being lost from the pipe underneath....sorry for the longwinded reply/explaination..oooooo:confused:
grober
Scotland
W204 C200cdi estate
Get a garage with an exhaust gas analyser to sample the headspace above the coolant with the engine warmed up. It will pick up traces of exhaust gases entrained in the coolant. Its a very sensitive test. If this is positive its time for an individual cylinder compression test which will possibly help locate the origin of the leak. Then its head off time.
There is really no way to check the water pump except by visual inspection for leaks.
drmw
Yorkshire
www.autonomed.co.uk
Not sure I understand this - if water is being forced into the expansion tank I would have thought that pretty normal particularly with all the work just gone on until things (literally) find their own level - so if we have an expansion tank not bereft of water, no steam from exhaust, no water in oil, pipes under pressure, temp gauge showing 80c what indicates there's a leak??:confused:
StuggyZX10
The water is being forced back through the cap on the expansion tank and out the hose on the expansion tank from high pressure.. thus triggering the warning lamp on dash for low coolant level...my wife had to put in nearly 2ltr bottle today to top this up it was okay on Sat
turbopete
Spennymoor
at risk of suggesting the obvious, is the system bled properly?
StuggyZX10
Yes i did bleed the system too ......and tonigh i drove the car with the cap loose and it lost over 3 litres with it coming back up out of bottle..it was my understanding that if the cap was loose no pressure would be present and the level should stay the same ??...but it aint happening...could the pump be fitted wrongly?? or goosed although its new...when the water bottle is topped up and the car started the level does not drop at all and i thought it would eventually after a couple of minutes the water level rises eventually pour out over the expansion bottle??.........:confused::confused:
47p2
Scotland
W638, W140, W220, W639 All gone but not forgotten
The reason that the system is under pressure is to allow the water to reach the running temperature without boiling over (pressurised water has a higher boiling point). With the cap loosened it will inevitably boil over and come out at the weakest point (the expansion bottle).
My guess is that it has either a bad airlock or HGF
StuggyZX10
just out of curiosity what is the recommended way to actually bleed the cooling system ???
rpe2
Silchester
rad cap off, heater to hot, run engine, squeeze the hoses now and again.
Only squeezing the bottom hose to bleed.
You could remove the thermostat and put your finger in to see if the pump impeller is loose of turning.
If the pump was fault i would have thought that it would have boiled up,,if the water comes out before it is up to temp then the head gasket must have failed and it blowing the water out
turbopete
Spennymoor
often, if a head gasket is at fault, if you remove the cap, start the engine and rev it up a little. the level should drop a little and stay down. if it starts to rise again, and your sure its correctly bled, then its a head gasket failure. does it misfire on startup, as a matter of interest? especially first start of the day?
StuggyZX10
  • #18
Im of thurs/fri this week so i will take out thermostat and have a feel about:D see whats what with the impellar
StuggyZX10
  • #19
The car starts great no missfires, lack of power etc all is as it should be run perfect from cold right up to temp 80c in around 3-5miles give or take a mile or two depending on outside temp...its not been used today so i will go out now and try what you suggest with the cap of etc
been and done it the water dropped...stayed there mabye minute then started to bubble with air coming back up left it like that for 10 mins squeezeing bottom hose to force air out...topped up and also fitted anew expansion bottle cap...will see how it goes tommorrow......
StuggyZX10
  • #20
Just a follow up to my problem...its been over a week now since i changed the expansion cap for a new one and took the advice of a couple of member and bled the water system as advised.....and touch wood it has not leaked any water i will keep my eye on level for now ...but thanks again to all who responded to my plight thanks again..
