water pump
simon tompkins
hi guys im going to put a new water pump on my e280-96 model is there any other bits i should buy to put on at the same time and is it very difficult to do
as im going to have a go myself.
thanks simon
simon tompkins
  • #2
bump anyone can you help:lol::lol::lol::lol::lol::lol::lol:
new antifreze and a new gasket or seal. and maybe flush the system out while your on! cant say what theyre like to do. never done 1 im afraid!
mercmadjim
Cornwall
SLK230k
Hi Simon, I just did the pump on my 300TE, and with some advice from the good people on here it was quite an easy job, I took my time and used the new seals that was provided with the pump and all went well.
Good luck and let us know how it goes.
simon tompkins
thanks mate do i have to take the v belt off also when using the gasket should i use gasket seal,
thanks simon
Would you like the workshop info to do this job
kth286
E320 Coupe 95
It is probably the straight six twin cam engine and book time is of the order of 6 hours.
I bought a genuine Merc pump because I did not want to be doing that job again in a hurry, and as the car is a keeper it should last another 150K miles.
Hoses and pipe seals and thermostat and fresh coolant (again Merc because it is ph neutral and will not be eating your internals and causing sludge build up in the passages) Also water from Halfords not the hard tap water.
The big secret is to have thin quarter inch socket and wobble set to access the in-accessible inner two pump bolts.
So a fair amount of front engine dismantling and with the front engine coolant pipe and the one going to the rear engine heat exchanger make sure you renew all pipe seals.
See russian diagrams.
When draining coolant a reminder there is a tap to empty the block, on right hand side of block.
I have sent the paper for the 104 engine, as it is a 1996 car
rpe2
Silchester
thanks simon
Nothing further to add on the above, not the nicest of jobs.
Make sure you order the correct pump from MB using your chassis no. as there are a couple of variants.
simon tompkins
thanks television does it matter if i use apatent part or is it recommended to use genuine mercedes.
thanks simon
thanks simon
The ones from Euro and GSF are good as I understand it
www.ckinsurance.co.uk
