emimec
- May 3, 2010
- Location
- London
- 1989 124 series 260e, 1992 124 series 260e (written off, used as spares), 1991 260e 124 series
Problem was in another post with same title... 124 series 260e petrol 1991.
But to recap, drive through a puddle and engine either faultered or died.
Decided to give the engine a good squirt of water from a squeeezy bottle while it was running, all ok on plugs, leads ignition amp crankshaft pulley etc, but then when water hit the coil, sparks all over the place, and engine died. Closer inspection when it ran again, revealed a spark going from the centre part of the windings to the metal frame.
To cut the story short, changed the coil with one from a donor car, a Beru made one. Inspection of my original coil shows 4 cracks in the casing, and a tiny pin hole, which I assume was from where the sparking came from, photos attached.
Only put this on the site to assist if anyone else gets a similar problem
Bob
Bob
