Conor
- Jan 22, 2019
- Location
- London, UK
- 2010 S212 350 CGI // 2004 R230 500
SL....Wow they look grim !!
What year is your E class ?
My mistake I thought they were from his SL.??
They might be worseMy mistake I thought they were from his SL.
Well they'd be older if original ...They might be worse
E class is 2010 but with 196k miles.
SL is 2004 with 78k miles.
I am expecting a verrrrry smooth ride after they are changed.. I wonder if it could solve the rich error and oil consumption issue..
Somebody said before that bad ignition can cause the fuel to wash the oil off the cylinder walls? I don't know.
The middle one is definitely knackered. The insulator has broken on the side facing us.iridium or palladium tipped should do 60 to 100k... the electrode looks way to good to say they are knackered
the build up of crud its concerning …. does he understand what the throttle pedal is for ?
oh yes….
looks like a cam cover gasket might be weeping, the top one is wet all over the out side... and I guess drained in to the cylinder when you took it out?
I wouldn't expect a magic cure from this Conor , defo wont hurt of course
Does the car smoke for a few seconds on start-up if so your valve stem seals may need replacement but at circa 200k there will be some oil passing the piston rings which will foul the plugs relative to how much, if the car isn’t a smoker no harm in taking the plugs out once a year to clean them up
