What does a "twin" turbo do that a single turbo does'nt?
Discussion in 'Engine, Drivetrain, Fuel and Exhaust' started by Beemer2, Oct 23, 2012.
  1. Beemer2
    Beemer2 Active Senior Members
    138
    Oct 7, 2012
    South Lanarkshire
    Your Mercedes:
    2014 E250 petrol W212
    My W212 is a twin turbo. How is this different from a single turbo?
    Secondly what was the significance of the word Kompressor on certain models?
  2. Steve@Avantgarde
    Steve@Avantgarde Forum Supporter Authorised Forum Supporter
    6,825
    1,002
    Dec 8, 2009
    Bristol/Somerset
    Your Mercedes:
    C220CDI AMG Line Premium, SLR McLaren Roadster, SL55 & C32AMG
    Before you may have 2 exhaust chambers merging into 1 powering 1 large turbo, now you have 2 seperate chambers with 2 smaller turbos. Better power output, depending on the design maybe more efficient.
    Kompressors are superchargers, so rather than using recycled exhaust gasses, it uses fresh air forcing it into the engine at a higher rate.
  3. star
    star Forum Supporter Authorised Forum Supporter
    5,543
    984
    Oct 6, 2004
    Reading
    Your Mercedes:
    Smart + others :)
    Plus turbo lag will be much less.
  4. Naraic
    Naraic Moderator
    10,328
    942
    Mar 4, 2010
    Your Mercedes:
    2005 CL500.
    ...and superchargers are crank driven...and have no lag as compared to the turbo charger.
  5. Wirral_guy
    Wirral_guy Active Senior Members
    998
    Jul 12, 2009
    Ness, nr Chester
    Your Mercedes:
    2004 CLK270cdi Avantgarde
    From how I understand it - the 2 turbochargers are set-up to operate most efficiently at different parts of the rev range - effectively spreading the boost more evenly.
    As has been said - a kompressor (compressor\supercharger) is a mechanical way of achieving the same thing as a turbo (i.e. forcing more air into the engine) run from the engine itself rather than the exhaust gasses.
    Dave
  6. Still Learning
    Still Learning Senior Member
    118
    Oct 12, 2011
    Newport Pagnell
    Your Mercedes:
    SL350 2007 gone. Porsche Boxster 2011
  7. SL55 Mark
    SL55 Mark Senior Member
    2,648
    354
    Oct 1, 2012
    South
    Your Mercedes:
    2004 SL55 AMG
    As Malcolm says, the twin turbo system traditionally used by Porsche (and possibly other manufacturers ?) uses one small turbo with lower inertia which spins up quickly at lower revs (from memory around 1,500-3,000) and one large turbo which kicks in from 2,500rpm and delivers maximum grunt. The idea is to reduce turbo lag, always the bane of single large turbo engines.
    As far as I recall Porsche introduced it with the 959 , in the mid 1980s, and followed it up with more mainstream cars like the 993 and 996 TTs from the
    '90s on.
    I'm trying to remember the layout, I think exhaust gases from both cylinder banks were unified and the turbos were effectively in-line ? I can check later.
  8. grober
    grober Senior Member
    2,941
    May 15, 2002
    Scotland
    Your Mercedes:
    W204 C200cdi estate
    In reply to your question - possibly cost a helluva lot more to replace if one of the twin turbo's goes AWOL.
  9. Naraic
    Naraic Moderator
    10,328
    942
    Mar 4, 2010
    Your Mercedes:
    2005 CL500.
    Malcolm posts a lot...but not in this thread so far.;)
  10. grober
    2,941
    May 15, 2002
    Scotland
    Your Mercedes:
    W204 C200cdi estate
  11. wireman
    wireman Senior Member
    2,632
    3
    Sep 20, 2005
    lancashire
    Your Mercedes:
    There are two approaches to twin turbo charging, the complicated big one little one with fancy manifolds and the two same size smaller ones which offers much reduced lag and decent high output performance without complex manifolds, on a six pot cyls 123 drive one turbo and cyls 456 the other, all in cheaper than one big one and far better for road use.
  12. EmilysDad
    EmilysDad Senior Member
    9,218
    2,744
    May 8, 2012
    Bury Lancs
    Your Mercedes:
    ML350
    I hope you don't do the spannering ........ :shock::shock:
  13. FIBAMAN
    FIBAMAN Senior Member
    343
    Nov 13, 2006
    TYNESIDE
    Your Mercedes:
    C180,C180,E300TURBO DIESEL
    Car manufacturers have tended to follow industrial engine developments, I recall first seeing a turbo charger on an engine built in 1953 / 54. Last one I worked on had 3 turbo chargers (9 cyl Sulzer 900mm bore 23,500 shp).
  14. Bolide
    Bolide Senior Member
    3,294
    Sep 17, 2002
    Your Mercedes:
    BMW 525 Diesel Touring
    Porsche and BMW are triple-turbocharging car engines now
    I remember seeing a Porsche 928 V8 on a stand at the Motor Show at Earls Court. It had been prepped for offshore powerboat racing and had two turbos, each about a foot in diameter. Shame it wouldn't fit under the bonnet of a road car...
    Nick Froome
  15. mersum1es
    mersum1es Senior Member
    1,956
    229
    Sep 25, 2010
    Finland
    Your Mercedes:
    Jep, and lot of development still going on in industrial side (both 2-stroke and 4-stroke diesels) due to new emission standards, for example
    http://www.abb.com/product/ap/seitp324/996d26edc83f4a81c125770b0053247f.aspx I believe we may see someday these Miller-cycles etc. also in passenger cars too.
  16. FIBAMAN
    343
    Nov 13, 2006
    TYNESIDE
    Your Mercedes:
    When are they going to start fitting fold out wings?
  17. SL55 Mark
    2,648
    354
    Oct 1, 2012
    South
    Your Mercedes:
    2004 SL55 AMG
    Sorry, it was wirral_guy :D.
    I saw the avatar and got them mixed up. :shock:
  18. richardN2O
    richardN2O Senior Member
    629
    16
    Feb 14, 2012
    Guildford, Surrey
    Your Mercedes:
    CL55 AMG Kompressor
    Nothing todo with Mercs, BUT when my mate has finished his "Street Legal" Dragster, I'll post some photo's.
    His Twin Turbo'd 9 Litre V8 has turbo's the size of buckets :)
  19. OP
    Beemer2
    138
    Oct 7, 2012
    South Lanarkshire
    Your Mercedes:
    If I recall correctly the Saab 900 had a turbocharger that only kicked in at higher revs. Does the MB twin run continuously or only at higher revs?
    I'm still enjoying the thrill of the acceleration from around 30mph up and it seems as if the acceleration is not linear but increases which is making me think that the turbo system is a factor in this?
  20. wireman
    2,632
    3
    Sep 20, 2005
    lancashire
    Your Mercedes:
    Turbo chargers work off exhaust gas, the engine produces more gases at higher speeds and hence the turbo's turbine generates more power for its compressor, so yes all turbo charger systems work more at higher engine speeds, the trick is to size the turbo for the required application and provide controls that are effective in regulating its behaviour, in days gone by the waste gate was the only control, hence the early Saab's small(ish) turbocharger led to awful narrow power band engine characteristics, today we have variable turbine nozzles which can greatly widen the operating range of a turbo system.
    Modern applications significantly improve part throttle economy and reduce emissions, in my opinion the only valid reason to add the complication of a turbo.
Share This Page
