ricky s
Anyone got linguatronic fitted, intrested to know how and what the voice operation can control. Thinking of having it retro fitted, but not quite sure how much control there is, thanks Rick
Many thanks for that imfo television, sounds very much along the same lines as a Becker nav system I had fitted in my old 240, which whilst very good, you had to be quite accurate with your wording. The activation for the lingutronic, I am told, is fitted to the cruise control lever, is that correct.
Braybrooks say they can retro fit, completley as factory fit, for £720, I thought that was reasonable. Is it worth it?
If I lift the lever and say "CD5 track 2 " it will play that CD and track.
it is as simple as that. I can use it for an address in the NAVIGATION, it will phone anyone of you choice, it will tune the radio to the station that you want also the TV, if you use the right words its perfect, if I said "telephone David" she might turn the TV on so you have to use the right words.
its OK more use full for the Nav and Phone.
Malcolm
