What is the correct tire presure?
Discussion in 'Bodywork, Tyres, Wheels & Trim' started by col320ce, Oct 17, 2012.
  1. col320ce
    col320ce Active Senior Members
    212
    Jun 23, 2009
    Australia
    Your Mercedes:
    320CE Sportline
    The info on the petrol cap is different to that on the drivers door. Which is correct do you think?
    1993 320CE Sportline C124, Australian car
    Thanks for any help...
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
  2. mikestrivens
    mikestrivens Senior Member
    2,715
    146
    Nov 21, 2008
    Stockport
    Your Mercedes:
    I always refer to the one on the fuel filler flap.
  3. oigle
    oigle Senior Member
    3,042
    349
    Mar 15, 2005
    Your Mercedes:
    Currently 2003 ML270. 2012 Nissan Maxima 250SL.
    Regardless of the above, you have illegal tyres on your car. You must replace tyres with at least the same load and speed rating as the originals. The only vehicles that are free of this rule are 4WD SUV's where a minimum of H rating applies. Your insurance company could refuse a claim on your car.
    As far as pressures go, it depends on how fast you drive and whether you value comfort ahead of handling or vice versa. I'd start at 32psi and go from there according to your tastes. My ML runs at a recommended 32 on 235/65 tyres with no issues. Anything much above that on our roads makes for a harsh ride.
  4. television
    television Always remembered RIP
    164,074
    309
    Your Mercedes:
    The label says 91 and the tyre says 91 for the load rating and that is correct.
    I would use the lower setting in on the label or the ride can be far too hard
  5. toby1
    toby1 Senior Member
    4,896
    163
    Mar 13, 2007
    West Berkshire
    Your Mercedes:
    1998 CL420 C140
  6. television
    164,074
    309
    Your Mercedes:
    H is good for 130 mph,,,,,is anyone going to pick up on that
  7. toby1
    toby1 Senior Member
    4,896
    163
    Mar 13, 2007
    West Berkshire
    Your Mercedes:
    1998 CL420 C140
  8. Ben Longden
    Ben Longden Senior Member
    410
    May 30, 2010
    Echuca, Victoria, Austrayamate
    Your Mercedes:
    W203 220CDI. Silver with grey and black trim. 1992 W140 400SEL Silver. 1999 CLK430 (missus)
    Not so sure about the legal statement here, Oigle...
    had a quick check of the Australian national rules (www.infrastructure.gov.au and vehicle standards bulletin 14, national code of practice, and specifically the tyres bit... it says... (and apols for whacking in a pile of text, but if Col's 320 CE is running illegal shoes, then 99% of us are also in the same boat.)
    A motor vehicle under 4.5 tonnes GVM which is required to comply with ADR 24 (which just says every car built after 1972 and on Aussie roads has gotta have a tyre placard) may be
    equipped with tyres other than those listed on the tyre placard provided that:
    the load rating of the tyres is not less than the lowest load rating listed on the tyre
    placard of the vehicle or equivalent variant of that model vehicle;
    the speed rating of the tyres fitted to a passenger vehicle is at least 180 km/h (S) when
    the tyre placard requires a higher speed rating than S;
    the speed rating of the tyres fitted to vehicles with special features for off-road use of at
    least 140 km/h N when the tyre placard requires a higher speed rating than N; and
    for all other vehicles a speed rating of at least 120 km/h.
    In special circumstances, the speed rating may be less than the ratings specified above
    if the speed rating of the tyre is more than the vehicle’s maximum speed. This will
    need to be confirmed with the Registration Authority.
    As for the pressures....
    Well, my W140 says 27 psi all round on the fuel filler cap, but I have worn out a set of shoes on the sides by doing this. I spoke with the tyrefitter, and while MB did write the specs for the tyre use, his suggestion was to run them all at the max load pressure. In my case 34 all round.
    As MB will refer me to 'the book' ie, 27 psi, and a guarantee of premature wear, Im doing a trial for the next 8000km until tyre rotation takes place, when any wear issues due to pressure will be looked at.
    I did another thread on this...
  9. toby1
    toby1 Senior Member
    4,896
    163
    Mar 13, 2007
    West Berkshire
    Your Mercedes:
    1998 CL420 C140
    I think every car I have ever owned always has 32psi all round - except when loaded up for a trip
  10. television
    164,074
    309
    Your Mercedes:
    Yes all of mine have been just fine at that figure, the only exception is the 140 that runs best at just under 30.
    I have to run the V70r at that pressure or I buckle the wheels on any pot holes, the ride is stone hard, but thats life :D
  11. oigle
    oigle Senior Member
    3,042
    349
    Mar 15, 2005
    Your Mercedes:
    Well, that is interesting, Ben. I have had tyre retailers refuse to fit tyres with lesser speed ratings than original - say it is illegal. Don't doubt what you have posted - makes more sense anyway (unusual for a Gov't body to come up with something that is sensible!!) Learn something every day.
    I was just taken with the statement on the placard which read "do not fit tyres with a speed or load rating less than specified" or something to that effect. The speed rating was V. Stupid anyway with our 110 top speed limit.
  12. Naraic
    Naraic Moderator
    10,328
    942
    Mar 4, 2010
    Your Mercedes:
    2005 CL500.
    Is it me...the label says 91V, the tyre 91H?
  13. oigle
    oigle Senior Member
    3,042
    349
    Mar 15, 2005
    Your Mercedes:
    That's what I was referring to.....91 is load V is speed rating.
  14. toby1
    toby1 Senior Member
    4,896
    163
    Mar 13, 2007
    West Berkshire
    Your Mercedes:
    1998 CL420 C140
  15. Naraic
    Naraic Moderator
    10,328
    942
    Mar 4, 2010
    Your Mercedes:
    2005 CL500.
    The blue label says the car should have speed rated tyres V, but the car has H. Clearly this is a 320 Sportline...and should have V rated tyres.
  16. television
    164,074
    309
    Your Mercedes:
    I only commented on the load rating and that was correct thank you
  17. Naraic
    Naraic Moderator
    10,328
    942
    Mar 4, 2010
    Your Mercedes:
    2005 CL500.
    You mentioned H...that's the speed rating.
  18. television
    164,074
    309
    Your Mercedes:
    So I made a typo that did not match my words, a big deal happy now
  19. OP
    col320ce
    212
    Jun 23, 2009
    Australia
    Your Mercedes:
    320CE Sportline
    Thanks for all the replies. This is more interesting and involved than I thought it would be!
    Just to confirm then:
    The filler cap says 35psi front, and 36+3=39 rear for normal driving
    and
    The Blue label says 32/33 front/back.
    So from what everyone is saying 32-ish is fine for a nice smooth ride but I can go up to 35/39 if I want to see the chiropractor weekly but be able to turn corners like Fangio?
  20. Naraic
    Naraic Moderator
    10,328
    942
    Mar 4, 2010
    Your Mercedes:
    2005 CL500.
    Very touchy...sorry.
Share This Page
