steve kane
- Aug 7, 2005
On two occasions now I have had to remove the Inlet Manifold and both times I have managed to dislodge a small dia plastic Vacuum Pipe that connects onto a rubber connector on the N/Side of the gearbox, the result is a very fierce Gear Change, like you would get by just dropping the clutch on a manual car, and its ****** fiddly to re-attach!
Anyway its clear that this Vac Pipe has a great bearing on the quality of changes, it connects the Gearbox with a small component with an electrical connection behind the N/S headlamp, then goes up to the Throttle Mechanism area where it connects to an Aluminum Box, a further Vac Pipe then travels back towards the engine, but I have not yet traced where this goes. Does anyone know what there components are and do?
Steve
Steve
