What one do I go by
Stulc
In the hills
W203 C180k
For mpg ie "after start" or "After reset" because there is nearly 10 miles difference
flowrider
SL500 (R230)
"After start" resets after every journey so it is only the mpg for the current trip, "after reset" covers multiple trips until you rest the counter.
rorywquin
North Yorkshire
An old B-Class.
One is longer term the other (after start) is your last trip. Both are relevant!
quinnj3
2010 E350 CDI BlueEfficiency Sport Coupe Auto 227bhp
And neither are accurate...
Agree, mine is consistently 3 mpg out from stated. Real mpg is always worse than displayed.
As above, however "After Start" will not reset just by turning key off and on. It requires a significant time lapse with ignition off (not checked exactly but over an hour). This enables trips to be measured where you may take a rest break or fuel stop.
Both counters can be manually reset using the reset button.
malcolm E53 AMG
Woefully inaccurate on short journeys (as you would expect) but very accurate over long distance touring of 500 miles (both measured brim to brim)
