Very nice!
If you're selling the blue ones, please drop me a PM
Leave it as it is!
I have an Avantgarde running standard size 235/40/17
If/when I decide to replace the 17s with 18s, I will go to 235/35/18 (I think I have that right but someone will correct me if wrong)
I don't think you need to go to 245 or gain anything (I assume this will be all round)
The standard tyre for our cars is 215/55 on a 16. This gives a diameter of 643mm.
The 225/40 on a 17 is 620mm. So, you are almost an inch too small...a 45 profile would be correct giving a diameter of exactly 643mm, the same as the standard tyre. You are probably using more fuel than you should.
If going to 18, then use 235/40 giving a diameter of 645mm.
I only bought my CL's and SL because of the seats
Thanks, Ciaran.
I'll be using 235's on the front, although the idea of using 245's on the rear makes some appeal. If so would it be 245/40 or 245/35?
TIA.
Paul.
If you use 235/40s on the front the correct tyre for the back is 265/35. This will give a diameter of 643...so only 2mm difference. Anything else and the CC will not work as it should. Even a 245/35 is too small at 629mm.
I'm not a genius BTW...just use this calculator:
http://www.etyres.co.uk/tyre-size-calculator
Then it's 235s all round. The only person to see them will be the car behind.:lol:
Thank you.
:Oops: Last question, I promise!
Which wheels bolts for these wheels, please?
I know I can get them from Alloy Wheels Direct, but I may be able to get a better price at the main dealer. I just need to know what to ask for specifically.
Part numbers - HWA1294010102 - B66031007
Wheel specs - 8Jx18 H2 ET31
TIA.
Paul.
