What type of “water” to dilute MB Coolant/Antifreeze? Distilled? Deionised? Pure Water?
Submariner1
Windsor Berkshire
CL500 2009 5.5
I have green/blue 325.0 Coolant in mine.
Needs to be diluted 50/50.
Some say Distilled water, others say Deionised (which is cheaper and more available).
Can I use Deionised any negatives?
I ask as my Dealer said they use tap water, but know this area has hideous hard water. Maybe they have a water softener?
If I get the Dealer to change the coolant should they drain down the the 2 cylinder banks of the V8? Or just the main radiator?
The main reason for changing the coolant is I noticed mine looked a lighter colour than my 50/50 mix for a top up.
Is one better spending the money on changing the coolant than having it tested to check its mixture strength.
I think it would cost about £33 to have it tested.
EmilysDad
Bury Lancs
ML350
what ever the engine V8 or not, I'd drain & flush until the water runs clear, drain as much as you can then add half the capacity with neat anti-freeze then top up to the max on the header tank. I suppose that I have the bonus of living in a very soft water area. If you're worried about how hard your area's water is I suppose you could use bottled water - though the 20 litre water bottles at work do produce a hard scale in the kettle.
Don't over think it ;)
Deionised water is more corrosive than distilled.
I would avoid deionised water like the plague.
If you have a condensing tumble drier or dehumidifier use the water from them.
mioba
Nottingham and Köln
Distilled is best.
The change interval is 15 years.
Have you tested the mix in the car at the moment.
The colour alone wont tell the condition unless its rusty :)
mioba
Nottingham and Köln
Funny that. I would have thought distilled would be more pure as it would remove every bit of leftoverfs during distillation.
Would be interesting whats in WIS if anyone has it handy.
Submariner1
Submariner1
Windsor Berkshire
CL500 2009 5.5
I felt embarrassed posing the question.
But you can see why I am unsure.
and Halfords sells water for Coolant and its Deionised.
No such thing as a stupid question, just my answers…:oops:
Jim2
1st Merc 2010 E Class W212 2.1 CDI. 2nd Merc 2014 E Class W212 220 CDI 3rd Merc 2018 E class W213
You are being a bit hard on your self and there Blobcat........without justification !!!, I'm planning to change the antifreeze in mine ( on the list of things to do ) and I have 10 Ltrs of G48 ready. Its made up of 5 Ltrs concentrate plus 5 Ltrs distilled water, same set up I used in the last E class I had. Now to get motivated to actually start the job.....:rolleyes:
Submariner1
Submariner1
Windsor Berkshire
CL500 2009 5.5
Distilled is best.
No not yet, because I wondered if it was worth spending the cash on a change rather than testing.
I think it should be changed every 15 years, so its 12 plus years already.
Benz Carl
W213
And what kind of coolant you put in a Merc ? W213 oem654 ? And I insist. Do i have to change the gearbox oil ?
Jim2
Google (
Google (Where would we be without it?) MB bevo list, and select your car, and it will tell you every liquid that's approved by M B for your particular car . Is the transmission manual or automatic?
mioba
Nottingham and Köln
If it aint broke dont fix it. Give it another 2 years and change the stat at the same time.
Jim2
My Eclass is 6 years old, and a few mths ago, the fuel filter housing had to be replaced, so the anti freeze had to be topped up. The garage said that they changed it, but I'm a bit skeptical..so I'll change it anyway, then I'll be happier knowing that it's the correct fluid ( G48) and not a mixture of God only knows what.
Benz Carl
W213
Google (
But I do google a lot before I come and ask here cuz I’m ashamed of my silly questions and maybe you senior guys don’t want to hear noobies around here.
Got one thing from comments G48.
NJS5
Catherington, Hampshire.
2011 R230 SL350, 2016 Discovery 4 Landmark, 1973 MG B GT V8, 1959 MGA roadster.
I know that it's not a Mercedes but I have topped up & refilled the cooling system on my MGB GT V8 since it was 1 year old with antifreeze and tap water.
I have had no problems with the cooling system, still on the original radiator, and have only replaced the water pump once. That replacement was due to a major engine rebuild & upgrade, rather than strictly necessary.
NJSS
