What's involved in removing oil filter housing cover on w124
Discussion in 'Engine, Drivetrain, Fuel and Exhaust' started by mercmancdi, Nov 12, 2012.
  1. mercmancdi
    mercmancdi Senior Member
    3,254
    696
    Dec 6, 2011
    templepatrick - co antrim
    Your Mercedes:
    2009 E250 cdi 08 cls320 cdi ,2007 e280 cdi '2005 E 280 CDI ,VW TOUAREG ,JAGUAR S AND xTO NAME A FEW
    Thinking of trying to remove broken glow plug in a 95 w124 e300 d but its the one behind oil filter housing ..What's involved in removing oil filter housing cover on w124 anyone know if it straight forward.
    Or advise me if there's been a previous post on this.
  2. wireman
    wireman Senior Member
    2,632
    3
    Sep 20, 2005
    lancashire
    Your Mercedes:
    On the 602/3 engines it just bolts onto the block.
    A new gasket will be required.
  3. OP
    mercmancdi
    3,254
    696
    Dec 6, 2011
    Your Mercedes:
    Thanks,almost looks too easy.
  4. SilverSaloon
    SilverSaloon Active Senior Members
    721
    Apr 15, 2004
    Your Mercedes:
    w124/1994/om606
    do you mean a "dead" glowplug or a physical broken/snapped one?
    if its just dead you can remove the plug without removing the filter housing. Get a bendy socket attachment and its accessable fairly easily.
  5. Doug1234
    Doug1234 Senior Member
    615
    72
    Jun 28, 2009
    Bedfordshire uk
    Your Mercedes:
    1997 w210 e300td
    Fully agree with the above statement, I changed all of mine on my OM603 with the inlet manifold still in place.
    Use 1/4 inch drive ratchets etc and there is room to get at them all,the rearmost ones need throttle mechanism cable tied open to give access but all in it is an easy job,well mine was as they all came out as if they had only been fitted the day before but I guess I was just lucky.
    Do get the engine part warm as it helps them come out much easier .
  6. OP
    mercmancdi
    3,254
    696
    Dec 6, 2011
    Your Mercedes:
    I am afraid it's broke off flush where the hex head was but the core is still there with the wire still plugged on,, only bought car and went to change the glowplugs and this is what I discovered . Never took a broken one out so a bit frightened.. Can't even find anyone to take the responsibility of taking the job on.
Share This Page
