lanciaman
- Sep 25, 2009
- Location
- Aberdeenshire
- E220 Cabrio (A124) - 1994
- Thread Starter
- Thread starter
- #21
Seems to be a French theme going on here!!!!
just wait untill the injectors, fuel rail, leak off pipes start to fail,oh an the maf decides its had enough. when I worked for Vauxhall the amount of these failures that we used to see on these would surprise you. its not even the vx engine
I'm sure if you did some CCW rotation you could get your house back...Cheers, we had to get rid of the house as the subsidence was awful!
Edit, not sure, the driveway looks ok and the cars verticles slightly distorted. Not sure what went wrong there, wide angle lens and stood quite close to the car might throw these shapes....
Opel (Vauxhall) Vectra 1.7TD without a doubt was the worst car I ever had. Everything except the engine went wrong. Then the engine went wrong !!!
Probably shot with a 28mm prime, so fairly wide.
I'm assuming on an FF so fairly wide. I assume you were very close to the car, thats whats done it. Nice lens though, you can just tell...
