I've been poking around the engine bay cleaning out the water drains and came across the wire/plug tucked into the NR drain
I'm not sure where it should go
Any ideas?
I don't know what it is, but from experience I've seen a lot of connectors on cars that actually have no purpose, IE they use the same loom for a model range and depending no the model that part of the loom may or may not work, much like the fuse box for example.
Now I could be talking a load of old cobblers in this case, but, if everything is working then I wouldn't worry about it
Wiring looms tend to be relatively generic across a particular model range or at least a derivative type, due to being a supplier part, along with the need to simplify logistics and manufacturing processes.
There are probably more unused connections tucked away.
You lost your key ? Or maybe you need a spare!
Your vehicle imobilliser does not respond anymore?
WE CAN FIX THEM ALL !! Mobile !
Save Time and Increase Profits With us !
