I've been poking around the engine bay cleaning out the water drains and came across the wire/plug tucked into the NR drain
I'm not sure where it should go
Any ideas?
I don't know what it is, but from experience I've seen a lot of connectors on cars that actually have no purpose, IE they use the same loom for a model range and depending no the model that part of the loom may or may not work, much like the fuse box for example.
Now I could be talking a load of old cobblers in this case, but, if everything is working then I wouldn't worry about it
Wiring looms tend to be relatively generic across a particular model range or at least a derivative type, due to being a supplier part, along with the need to simplify logistics and manufacturing processes.
There are probably more unused connections tucked away.
AIB understand your special Mercedes deserves a special insurance policy. We have a refreshing attitude to insuring high performance, modified, imported or classic and vintage cars and deal with the UK’s leading insurers. We offer discounts for length of ownership, where the vehicle is kept overnight and limiting the mileage and can also cater for those clients who need higher mileage and business use.
To obtain a quotation please call the team on 02380 268351 or visit us atAIB Insurance
