Wheel speed sensor Replacement Question
mrix
Year 2013 W204 Model C350
Hello all, I have attempted the Wheel speed sensor replacement on my W204 C350 2013 Model today and while about to plug the socket in the wheel arch section I noticed it had two separate positions but only the wheel speed sensor plugged in ? on countless YouTube videos I have seen a like a left and right socket that clip together to make one socket ? Please tell me my model does not require the other lead ?
If it does I have no idea what has happened and why its gone...
Thanks for any feedback
Does the opposite wheel set up help if you check it ?
M
mrix
Hello and thanks for the reply, if I was to check and still see the same missing a lead I would still ask the same question etc, I suppose if there is one actually there I would know I suppose
M
mrix
The offside has two leads, one for the pad wear sensor, the other for the wheel speed sensor. The nearside does not have the pad wear sensor fitted, hence the vacant slot
That`s a huge relief thanks for that.
