Wheel Woolies Review
S.Speed
Lancashire
Older Citroen Now :-(
My review of the “wheel Woolies” wheel cleaning kit
Firstly I must stress that my wheels were just dirty and not filthy..
Nevertheless this review is relevant because not everyone has a bi annual wheel cleaning cycle!
The kit comprises of 3 “woolies: (1st photo)
The longest Large Wheel Woolie is 440mm long and has a 75mm diameter wool head. Use this long handled Wheel Woolie to reach deep into the wheels.
The Medium Wheel Woolie is also 440mm long with a 45mm diameter wool head. This one is ideal for smaller wheel gaps, air diffusers, door jams, engine areas, etc.
The Small Wheel Woolie for small gaps, like grilles, and narrow spoke wheels. It is 200mm long and 25mm in diameter.
The first thing you notice when using the large “woolie’ in particular is the weight of it as you remove from the bucket of soapy water is its weight.
Unlike conventional brushes these woolies hold loads of water!
They aren’t actually brushes in the true sense.. More like furry mops.
They are very soft and are much LESS likely to damage the Alloy wheel lacquer that some of the stiff wheel brushes out there.
Photo 3 shows the large "woolie" in use full of soapy water.
Photo 4 shows how deeply you can go with these. Its easily up to going right through the wheel to the far side.
Photo 5 shows that you angle the "woolie" in order to get to the inside of the spokes... Incidentally they also do a "woolie" with a 90 degree bend in its neck to get behind the spokes.. I think its called a "Rashman Woolie" Lol
S.Speed
S.Speed
Lancashire
  • #2
Wheel Woolies Review Part 2
Part 2:
Photo 6 shows the use of the medium "woolie" to go between the wheel and calliper.
Photo 7 & 8 show the small "woolie" in use.. Its particularly good at cleaning inside the wheel bolt holes.
I did the wheels alone first to get the photos for this review.. Then I had to wash the rest of the car as the wheels showed her up..
Photo 10 shows her rewarding me for my efforts.
The point I need to make that the photos DONT show is just how easy the "woollies" are to use.. More to the point how thorough a job they do.
Remember this isn't just a quick flash over the wheel face..
This is an inside and out clean.
As I mentioned before they hold loads of water.. That's something that NO Brush can do !!
On a side note.. I am sooo glad i kept the 17" wheels..
The Black Chrome colour that I had them redone in is gorgeous and I dont regret my choice for 1 minute!
S.Speed
S.Speed
Lancashire
I am signed in and ticked the "remember me" box and the damned edit time is way too short..
No other forum has a 5 minute limit..
It makes NO sense !!!
Thank you for the write up,, maybe I should get some as my 10 year washing up brush is getting past it.
The bit that persuaded me is that they will go between the wheel and the caliper, so the car does not have to be moved
S.Speed
S.Speed
Lancashire
Correct Malcolm..
Very good product and very kind to the lacquer..
Yes they are expesive but then so are Alloy Wheels!
Developer
S212 E63 S 5.5 biturbo
You're such a scrubber Simon........
