Wheels Squeaking
sjlee6
A200 Cdi Auto , 2014, 2143cc, 136BHP
I have had now for a while a squeaking problem which sounds like its coming from my wheels. I took it to a Rhinos Tyre dealers who tried to resolve the problem by using some emery cloth on the brake disks as they thought it was catching but this didn't work. I had the brake pads changed only last November and are still in very good condition. The squeeking happens usually when I'm driving around 5-20 mph and is getting very irritating, any help would be appreciated on this.
Conor
London, UK
Hello, how many miles have you done since November?
Are the pads work, my pads currently need replacing and squeak at same speed - it's the wear sensor. A friend had a similar problem to you and mentioned the calipers were sticking..
Did the Rhino people comment on that?
mioba
Nottingham and Köln
The squeaking coulle be one of many things, suspension, drop links ARB bushes, calipers, dry backing pplates on pads, rubbers so on and so forth.
If it was the disks they would need machining as I doubt an emery cloth would do much at all.
I would suggest going to a proper mechanic and not a tyre dealer.
sjlee6
sjlee6
Since november roughly between 5-7K as I only drive it half of the year as i work away.
Yes pads seem fine when braking, I mentioned that the callipers were sticking but they had it on the ramp and said that this was fine?
sjlee6
sjlee6
Thank you Mioba, I will be sure to take it next time I am home somewhere different and mention the suggested problems you have to them and see what they say!
Flyinspanner
Ruislip
Maybe pop the pads out and put copperslip on the back?
chamfer leading edge of pad with a file.
if squeak persists get silicon grease spray and squirt on ARB bushes.
If still there, spray drop links etc, go through all bushes & joints one by one- that way you get to positively identify the culprit.
sjlee6
sjlee6
Yeah I will give this a go, thankyou Flyin Spanner!
DREAMER NO2
W124 2.6E M103 1989
To rule out items in the brakes making this noise jack the wheel up and spin it - no noise then it will be something else on the suspension like the rubber bushes or links ..
