anyweb
- Jul 15, 2005
- Age
- 58
- Location
- Sweden
- Website
- www.niallbrady.com
- c238,w120 (diesel)
hi guys,
when i hook up a trailer to the built in removable tow bar on the car (and corresponding electical port) if i indicate left or right on the car, nothing happens on the trailers lights but my indicator lights on the car blink very fast as they would do if a bulb is blown, my car is a merc C220 1995 version)
so i tried the trailer on our chrysler voyager, no issues at all,
the only difference between my car and the chrysler is i use a 'supplied' adaptor to convert from what i presume is a 15 point 'german' connection to i think it's 9 point swedish standard (i'm no electrician)
long story short, i replaced that connector, and still have the same issue, so how do i go about figuring out what wiring is causing the problem,
points to note:
* the indicators work fine on my car when the 'adaptor' is removed
* the indicators flash fast when the adaptor is connected regardless of whether the trailer is also connected to the other side of the connector or not
* the supplied connector was replaced and the same problem occurs with the replacement
cheers
anyweb
points to note:
cheers
anyweb
