Where is the evaporator temp sensor for the climate control please?
nickh
On my 1998 w210 eclass 320?
according do the diagnostics on the climate this is may be up the spout? which is stopping the A/C staying on..
nickh
nickh
Thanks.. thats good made me laugh.. but where in the car is this sensor? according the diagnosics on the climate control it recons its readin 62 degrees constantly, making my a/c shut down..
nickh
nickh
OK Does anyone know where the evaperator sits for the A/C in the w210 e-class..
the stealerships seem to be a bit"bring it in and it will cost you so we can tell you" ..
thanks
piestore
manchester
evap temp sensor
OK
It's the same on both cars, remove the radio and center console and the temp sansor is cliped into the heater box in this area, the usual symptom of this failing is it all works well to start with and then after 10-15 mins driving air flow is reduced to allmost nothing due to the evaporator becoming a solid block of ice, Its about 45 mins work to replace and test
Keith
nr Cambridge UK
Does this sound like dud evap temp sensor?
piestore said:
OK
thanks for that - but my symptoms not quite the same on my 124 :
I have checked that the compressor engages when I first switch aircon on with engine running however it keeps dropping in and out say every couple of minutes or so - result air is only lightly chilled. Does this sound like the evap temp sensor or something else? Have also checked that fluid is present without bubbles and looks fine. ambient temp only 13C at present btw.
OlafMaxwell
Cork Ireland
W210 E320 CDI Estate
I had aircon trouble on w210. Problem was the condenser rasdiator, located behind the passenger side suspension strut under a removable cover. Those condenser radiators are a known problem, they all end up leaking and a/c goes awol. You can hear the compressor trying to compress non existent refrigerant. You should check it out because it costs to regas it and the regassing will just leak again. Its not really a great a/c system, struggles to keep temperatures down in hot weather [as in 40C in France].
